Solve Gas Law Problems: Volumes, Pressures, & Temperatures
  • Thread starter Thread starter DoctorReynaldo
    Gas Gas law Law
Gas law problems discussed include calculating the volume change of a balloon as it rises from 300 kPa to 200 kPa, determining the height a column of water can be lifted by one atmosphere, and finding the new volume of gas when cooled from 27 degrees Celsius to -73 degrees Celsius. Additional calculations involve determining the original temperature of gas when its volume changes from 12 L to 18 L at constant pressure, and the new pressure of gas heated from 100 degrees Celsius to 300 degrees Celsius at 620 kPa. The ideal gas law and related principles like Boyle's Law and the Combined Gas Law are emphasized as essential for solving these problems. The discussion also touches on the relevance of these concepts in chemistry and physics, with some participants expressing uncertainty about their familiarity with gas laws. Understanding these principles is crucial for accurately solving gas law problems.
DoctorReynaldo
Gas Law Problems
A gas-filled balloon occupies a 4-L volume at a pressure of 300kPa. What volume will the balloon occupy if it rises to a height of where the pressure is 200kPa?
Calculate the hieght to which a pressure of one atmosphere can life a column of water. Mercury is 13.6 times as dense as water.
a 60-m^3 volume of gasy is at a temperature of 27 degrees Celsius. Under constant pressure the gas is cooles to -73 degrees Celsius. Calculate the new volume of gas.
While held at a constant pressure, 12 L of gas are heated at 127.5 degrees celsius. If the new volume is 18L, what was the original temperature of the gas in degrees celsius?
A gas is kept in a closed container at 620kPa. The gas is heated from 100 degrees celsius to 300 degrees celsius. Calculate the new pressure of the gas.
a 6.0-L volume of gas has a pressure of 140 kPa and a temperature of -14 degrees celsius. What will be the pressure of this gas if the volume is reduced to 1.5 L and the temperature raised to 504 degrees celsius?
The density of air is 1.3g/L at standard conditions of 101 kPa and 0 degrees celsius. Determine the mass of 3.0 L of ait at a pressure of 138.2 kPa and a temperature of 273 degrees celsius.
One atmosphere of air pressure supports a column of water approximately 10.3 m high. A 2.0 cm^3 bubble of air is released by a diver working 62.4 m below the surface of a deep lake. If its temperature remains constant, what is the volume of the bubble as it reaches the surface? Hint: the pressure on the surface of the lake is on atm.
I think these can all be solved using the ideal gas law, pv=nrt
Since you didn't ask specificly for direction and have shown no work, this is about the most help you can expect to get here.
Hint:
and the answer is in another problem:
I just got done with this lesson in chemistry. Most of those can be solved using the Boyle's Law and Combined Gas Law.
boyle's law - P1/P2 = V2/V1
Combined gas law - P1V1/T1 = P2V2/T2
P-Pressure
V-Volume
T-Temperature
*You might have to get P1 by using PG=Patm-Hg or PG=Patm-Hg-H2O
*Remember to change Celsius to Kelvins (C + 273)
There's some problems on there I don't know how to do.
I don't know why this is on a general physics forum. I've haven't had
physics yet. Am I going to see Gas Law again?
Beams of electrons and protons move parallel to each other in the same direction. They ______. a. attract each other. b. repel each other. c. neither attract nor repel. d. the force of attraction or repulsion depends upon the speed of the beams. This is a previous-year-question of CBSE Board 2023. The answer key marks (b) as the right option. I want to know why we are ignoring Coulomb's force?
