Maximizing f(x,y) on y=1-x^2 using Lagrange Multiplier Method
The discussion revolves around maximizing the function f(x,y) = 2x + y on the curve defined by y = 1 - x^2 using the Lagrange multiplier method. Participants are exploring the relationship between the function and the constraint provided by the curve.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss the application of the Lagrange multiplier method and the process of substituting found points into the function to determine maximum values. There are questions about how to correctly evaluate the function at the identified point (1,0).
The discussion is ongoing, with participants providing hints and encouragement. Some express frustration and seek further guidance, while others attempt to clarify the steps needed to evaluate the function at the identified point.
There are indications of emotional responses to the problem-solving process, with participants expressing feelings of being stuck and overwhelmed. The original poster's attempts and the responses suggest a mix of confusion and a desire for reassurance.
sara_87
Question:
Use Lagrange multiplier method to determine the point on the curve
y=1-[tex]x^2[/tex]
that maximises the function f(x,y)=2x + y.
Hence find the maximum value of f.
Attempt at Solution:
Okay I used the Lagrange method to get a point on the curve and I got (1,0)
How do I find the maximum value of f though?
If you've found the values of x and y where the function has a maximum, then do you not just plug (1,0) into f(x,y) to obtain the value of the function at that point?
Uh, substitute (1,0) into f?
i get (0,0)?
f is a number. Not a point. And it's not 0.
i'm still stuck! i don't what to do lol
give me more tips before i give up on maths altogether!
(does anyone else go through a phase when they just want to give up? lol)
You say f(x,y)=2*x+y. You've found a solution (1,0) so x=1, y=0. What is f(x,y)? Don't get so flustered!
'Don't get so flustered!'
you don't know what kind of day I've had! lol
thank you for your help and time I'm sure it's not a hard question i'll think about it tomorrow when i feel more awake.
Your annoyance is blocking you from seeing the obvious. That makes it a really good time to take a rest.
  • · Replies 16 ·
  • · Replies 18 ·
