Understanding Newton's Laws of Motion
This discussion focuses on Newton's Laws of Motion, specifically the application of these laws when a force is applied to a box. The scenario involves a 40 kg box being pulled with a force of 20 N, resulting in an acceleration of 0.5 m/s² to the right. The conversation highlights the interaction of forces, including the equal and opposite force exerted by the box on the hand, and clarifies that the net force acting on the box determines its acceleration. The role of friction is also examined, particularly in a vacuum scenario where external forces are absent.
  • Understanding of Newton's First, Second, and Third Laws of Motion
  • Basic knowledge of force, mass, and acceleration calculations
  • Familiarity with concepts of net force and friction
  • Awareness of conditions in a vacuum and their effects on motion
  • Study Newton's Second Law of Motion in detail
  • Explore the concept of net force and its calculation
  • Research the effects of friction on motion in various scenarios
  • Investigate motion in a vacuum and compare it to motion in a medium
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of motion and force interactions.
Solidmozza
Hi,
This is more of a problem with concept rather than an actual mathematical problem, so forgive me if I don't use the template provided.
I'm just having an issue with Newtons laws of motion. If I were to pull a box across a floor to the right with my hand, assuming that the mass of the box is 40 kg and the force I use is 20 N, I know mathematically the acceleration is 0.5m/s^2 to the right. However, what happens to the equal and opposite forces? I mean, the box is exerting a force on your hand/body that is equal to 20 N but in opposite direction, but its inertial mass is less than that of my body so the box should still accelerate in my direction, right? But shouldn't the acceleration be less than simply 0.5m/s^2 to the right, because let's say my mass was 80 kg, the acceleration to the left = 0.25m/s^2 and the acceleration to the right is 0.5m/s^2, leaving me with a net acceleration of 0.25m/s^2 to the right? Is it just the frictional force that is combating the force of the box on me that prevents this from happening, and if so, is it just the case that the box doesn't have enough friction to oppose the force of my hand?
Additionally, if this above situation was conducted in a vacuum (me and the box just somewhere in a vacuum, no floor) would the acceleration to the right be 0.25m/s^2?
I know this is probably old hat and is simple stuff, but I appreciate the help!
Thanks
To understand how an object will accelerate you must know the net force on it. By stipulation, the 20 N force that you exert on the box is the only force acting on the box, so it's the net force on the box. True, the box exerts a 20 N force on your hand. But is that the only force acting on your hand? No.
