Help with formal definition of the limit of a function
The discussion revolves around the formal definition of the limit of a function, particularly focusing on the epsilon-delta approach. Participants explore how the proof of limits works and the potential for circular reasoning in these proofs. The scope includes conceptual clarification and technical explanation of limit proofs.
  • Some participants express confusion about the nature of the proof and its perceived circularity.
  • There is a discussion on the formal definition of a limit, with emphasis on understanding how values approach a limit as x approaches a certain number.
  • One participant mentions that the proof involves showing that values in a neighborhood of the limit become the same.
  • Another participant critiques the typical argument used in limit proofs, suggesting it appears circular because it starts from what is meant to be proven.
  • A later reply elaborates on the difference between a "true" proof and an analysis of how to write a proof, emphasizing the importance of choosing delta appropriately.
  • Some participants suggest that the perception of circularity may arise only in cases where limits exist, and that limits that do not exist do not exhibit this circularity.
Participants express differing views on the nature of circular reasoning in limit proofs, with some agreeing that it can appear circular while others argue that it is a misunderstanding of the proof process. The discussion remains unresolved regarding the implications of circularity in limit proofs.
Participants note that the analysis of proofs may not always lead to formal proofs, and that the relationship between delta and epsilon is crucial but can be complex. The discussion highlights the challenges in defining limits and the conditions under which proofs may or may not work.
j-lee00
The problem is not to conduct the proof but how the proof works. (It seems to be a circular argument)
Please use laymans english to explain, thank you
what are you asking?
how the proof works using the formal definition of a limit
with epsilon and delta?
yep that's correct
Formal Definition, so yup. Never really liked epsilon delta proofs myself, but anyway..
The proof works by showing that in the close neighborhood of the value that the limit is approaching, all the values in the neighborhood as becoming the same.
ok, firstly, you ask yourself how may you otherwise define a "limit"? if you think about it you will see that the formal definition of a limit make perfect sense... it is indeed what we meant by a "limit" that is: we want to see what happen to f(x) as x tends to a certain number x_0.
suppose we want to show
[tex]\lim_{x\rightarrow x_0} f(x) = L[/tex],
then we would like to know whether f(x) indeed gets close to L as x gets close to x_0. And that is exactly what the definition is doing.
now in proofs, you often want to find a relationship between [tex]\delta[/tex] and [tex]\epsilon[/tex]; and often what that does is to simply ensure that we can ALWAYS find the appropriate values for them so that the the inequalities involving [tex]\delta[/tex] and [tex]\epsilon[/tex] can be satisfied.
thank you very much
When you say "It seems to be a circular argument" you may be thinking of this:
To prove that [itex]lim_{x\rightarrow 3} 2x+ 1= 7[/itex] a typical argument goes "If [itex]|f(x)-L|= |2x+1- 7|< \epsilon[/itex] then [itex]\|2x- 6|= 2|x-3|< \epsilon[/itex] so it suffices to take [itex]|x-3|< \delta= \epsilon/2[/itex]".
That seems "circular" because we start from [itex]|f(x)-L|< \epsilon[/itex] which, by the definition of limit, is what we want to show. You are correct that that is not a formal proof- it is more like analyzing the problem to deciding HOW to write a proof- It is deciding how we should choose [itex]\delta[/itex] in order to get the result we want. A "true" proof would go the other way:
"Given [itex]\epsilon[/itex], take [itex]\delta= \epsilon/2[/itex] (which looks like the professor is picking it out of the air since the student didn't see the analysis above). Then if [itex]0< |x-3|< \delta= \epsilon/2[/itex], we have [itex]0< 2|x-3|= |2x- 6|= |2x+ 1- 7|< \epsilon[/itex]".
Typically, having done the "analysis" we don't need to write out the "true" proof because it is clear that every step in going from [itex]\epsilon[/itex] to [itex]\delta[/itex] is reversible- it's obvious that we can go from [itex]\delta[/itex] to [itex]\delta[/itex]. A "proof" where you go from the conclusion to the hypothesis by reversible steps, so that it is obvious you could go form hypothesis to conclusion, is sometimes called "synthetic proof". It's used a lot, for example, in proving trig identities.
the perception of a "circular argument" appearing only because in those cases (probably cases that you have been exposed to so far) it DOES work and that limit exists and does go to the number we want to proof. But i think all you need to see is an example of a limit that doesn't exist... and you will see that in this instance, you just can't find a delta and epsilon that work, no matter how hard you try... hence, this "circular argument" does not appear here. It looked like so before because it worked.
  • · Replies 25 ·
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 26 ·
