Creating a pH 6.7 Buffer Solution with Imidazole and C3H5N2Cl
  • Thread starter Thread starter ElectronicError
    Buffer
The discussion centers around the creation of a pH 6.7 buffer solution using imidazole and its conjugate acid, C3H5N2Cl. Participants explore the calculations and methods for achieving the desired pH while considering the available reagents and their concentrations. The context is primarily homework-related, involving theoretical and practical aspects of buffer preparation.
  • Homework-related
  • One participant outlines their calculations using the Henderson-Hasselbalch equation to determine the necessary concentrations of the weak base (imidazole) and the conjugate acid (C3H5N2Cl) to achieve the target pH.
  • The calculated pKa for imidazole is presented, leading to a derived ratio of base to acid concentrations.
  • Another participant questions whether all provided solutions must be used, suggesting an alternative approach that focuses on using imidazole hydrochloride as an acid and calculating the necessary amount of NaOH to reach the desired pH.
  • There is a request for further assistance, indicating uncertainty in the initial participant's solution and a desire for validation or correction.
Participants do not appear to reach a consensus on the method or calculations for preparing the buffer solution. Multiple approaches and uncertainties remain evident, particularly regarding the use of available solutions and the calculations involved.
The discussion includes assumptions about the concentrations of the solutions and the calculations derived from the Henderson-Hasselbalch equation. There is also a lack of clarity on whether all provided solutions must be utilized in the buffer preparation.
This discussion may be useful for students or individuals interested in buffer solutions, particularly in the context of chemistry or biochemistry coursework, as well as those seeking to understand the application of the Henderson-Hasselbalch equation in practical scenarios.
ElectronicError
I have worked through the problem and spent quite a bit of time on it but am not extremely confident in my solution. I would just like someone to check my work. Cheers.
-Need 0.4 L of an aqueous buffer solution of pH=6.7
-Have access to 0.02 M HCl, 0.02 M NaOH, 0.01 M C3H4N2, and 0.01 M C3H5N2Cl
-Will use Imidazole (C3H4N2) as weak base. Will use C3H5N2Cl as conjugate acid.
-Given Kb for C3H4N2 = 9.0 x 10^-8
-The buffer must have the capacity to absorb 20 mL of either 0.02 M HCl or 0.02 M NaOH and undergo a pH change of no more than +/- 0.1.
Henderson-Hasselbach
(Ka)(Kb) = Kw = 1 x 10-14
Ka * 9.0*10^-8 = 1 * 10^-14
Ka = 1.1 x 10^-7
-log(1.1 x 10^-7) = pKa ~ pH = 6.95
pH = pKa + log([base]/[acid])
6.7 = 6.95 + log([base]/[acid])
[base] / [acid] = 10^-0.25 = 0.56 (reasonably close to 1)
Use 1.56 x 10^-5 M for [base] and 0.001 M for [acid]
Buffer concentration = 1.02 x 10^-3
#mol weak base = (buffer concentration) * (desired final volume) = (1.02 x 10^-3) * 0.4 L = 4.06 x 10^-4 mol
0.01 M = 4.06 x 10^-4 mol / ? L
4.06 x 10^-2 L = 40.6 mL C3H4N2
In a 400 mL beaker, add distilled water to 40.6 mL C3H4N2 until most of the desired final volume is reached. Add HCl or NaOH dropwise until the pH reaches 6.7. Add distilled water to the 400 mL line.
Ummm..
:zzz:
This is my last, desperate call for help. Surely someone can lend a hand?
ElectronicError,
I have been trying to think about this one for you. Do you need to use all of those given solutions, or are you permitted to just use 2 or 3 of them?
My first attempt would be to begin with the imidazole hydrochloride and use it as an acid; find the amount of NaOH base titrant necessary to reach a pH of 6.7. Now, instead of performing that partial neutralization, think of the number of moles of imidazole which would be equivalent; and use correspondingly less amount of moles of the imidazole hydrochloride.
... I know that was not complete, but it might be a start. Take care in case I misjudged anything in that method.
  • · Replies 16 ·
  • · Replies 16 ·
