Are the Eigenvalues of a Unitary Operator of the Form e^i(a)?
The discussion revolves around the properties of eigenvalues of a unitary operator, specifically questioning whether they can be expressed in the form e^i(a) where a is a real number. The original poster expresses uncertainty about using Dirac notation and seeks alternative methods for understanding the problem.
  • Participants explore the relationship between unitary operators and their eigenvalues, with some suggesting that basic linear algebra concepts are sufficient. Others introduce the notion of isometry and the spectral equation, while the original poster seeks clarification on these terms.
The discussion is active, with participants providing hints and guidance on how to approach the problem without relying on Dirac notation. There is a mix of interpretations regarding the concepts involved, and no explicit consensus has been reached yet.
The original poster notes a lack of familiarity with certain terminology, such as isometry and spectral equations, which may affect their understanding of the problem. There is also an indication that the discussion is framed within the constraints of a homework assignment.
jnazor
A unitary operator U has the property
U(U+)=(U+)U=I [where U+ is U dagger and I is the identity operator]
Prove that the eigenvalues of a unitary operator are of the form e^i(a) with a being real.
NB: I haven't been taught dirac notation yet. Is there a way i can do this without it?
Assume eigenvalues exist
U(a)=x(a) => (U+)U(a)=(U+)x(a) => (a)=(U+)x(a)??
note that you don't need to understand Dirac notation, all you need to know is some basic linear algebra in finite dimensional space. hint: "of the form [tex]e^{i\theta}[/tex]" means that magnitude of complex e-vals are 1
HINT: U unitary means U isometry. Assume the spectral equation
[tex]U\psi =a\psi[/tex] (1)
has solutions in a Hilbert space [itex]\mathcal{H}[/itex].
Then use (1), the assumption regarding the space of solutions and the isometry condition to get the desired result.
Sorry I've never heard of isometry or the name spectral equation. I just know it as the eigenvalue equation.
Isometry means <x,y>=<Ux,Uy>. Why is this true for U unitary? Once you believe it's true set y=x and x to be an eigenvector of U. What do you conclude?
12K
  • · Replies 0 ·
