| Thread Closed |
what's reading for multimeter set to read dc voltage and bandwidth of 10khz |
Share Thread | Thread Tools |
| Mar12-07, 10:32 AM | #1 |
Happened to come across this qn:
Noise from receiver is measured by rms voltmeter with bandwidth 100khz, and voltmeter reads 2mV. what will be the reading for multimeter set to read dc voltage and bandwidth of 10khz? My ans is 10/100 x 2 = 0.2mV. cos smaller bandwidth reduced by a factor of 10. Can anyone comment whether my answer is correct? tks |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Mar12-07, 10:42 AM | #2 |
Recognitions:
Read the question carefully - in particular, the abbreviations "rms" and "dc".
| Mar12-07, 10:48 AM | #3 |
so u mean the voltage reading shdnt change? since rms value and dc value are the same.
| Mar12-07, 11:30 AM | #4 |
Recognitions:
RMS and DC are not the same if you are measuring an voltage that varies with time.
A DC meter measure the average (mean) value of an AC signal, which is zero for a symmetrical wave form like a sine wave or a square wave. Connect a DC voltmeter to a low voltage AC signal generator sometime, and see what reading you get - zero. The "noise" in the question is basically an AC signal so its average value measured on a DC meter will be 0. Check out what "root mean square" means, and how it is different from "mean" or "average". |
| Mar13-07, 06:47 AM | #5 |
Oh now i get it. Thanks for the explanation! ;)
| Thread Closed |
| Thread Tools | |
Similar Threads for: what's reading for multimeter set to read dc voltage and bandwidth of 10khz
| NASA develops 'mind-reading' [nerve signal reading] system | Computing & Technology | 12 | ||
| multimeter resistance | Engineering Systems & Design | 2 | ||
| 10kHz EM noise | Electrical Engineering | 3 | ||
| multimeter | Introductory Physics Homework | 2 | ||
| RPM with a Multimeter | Electrical Engineering | 2 | ||
