Acceleration, velocity, distance, speed and time help please
The discussion revolves around calculating the time and velocity for a fictional spacecraft traveling between two planets 100 million kilometers apart, with a constant acceleration of 9.8 m/s². Participants explore the implications of using classical kinematics versus special relativity in their calculations.
  • One participant outlines the parameters of the problem, including the distance, acceleration, and the need to calculate time and maximum velocity during the acceleration phase.
  • Another participant suggests looking at basic equations of 1-dimensional kinematics for potential formulas to solve the problem.
  • A later reply indicates that the problem requires consideration of special relativity, warning that using non-relativistic equations could lead to unphysical results, such as exceeding the speed of light.
  • One participant acknowledges the need for relativistic equations and expresses intent to work through the problem, mentioning the Lorentz factor and the speed of light.
Participants generally agree that the problem is complex and requires careful consideration of the physics involved, particularly regarding the transition from classical to relativistic mechanics. However, there is no consensus on the best approach or specific formulas to use.
Participants note the limitations of classical kinematics in this scenario, particularly the potential for arriving at unphysical results if relativistic effects are not taken into account. The discussion also reflects varying levels of familiarity with the necessary physics concepts.
Rich_M
Hi Everyone,
This might be a little too complex for me to understand the answer, But here goes:
1) I have a fictional spacecraft , frictonless and an infinite supply of fuel.
2) It is able to accelerate at 9.8 m/s/s.
3) I want to travel between 2 planets 100 million kilometers apart.
4) I want to accelerate 1/2 way then deccelerate the rest of the way.
I know:
distance = 100,000,000km = 100,000,000,000m
acceleration = 9.8m/s/s
time = ? in seconds
velocity = 9.8*time = ?m/s
I can break the trip in two 50,000,000,000m if I figure the time and max velocity for the acceleration phase, I know it for the deceleration phase.
if I remember right (high school physics was 30 years ago) I would travel
4.9m, ending with a velocity of 9.8m/s after the first second.
9.8m, (total 14.7m), ending with a velocity of 19.6m/s after the second second.
19.6m, (total 34.3m), ending with a velocity of 29.4m/s after the third second.
I know I could use a spread sheet and just keep doubling the distance, adding it to the total distance and add another 9.8m/s to the velocity until I got to 50,000,000,000m, But there must be a formula to figure this out, my question is where can I find the formula.
Thanks
Rich
Astronomy news on Phys.org
Rich_M said:
Hi Everyone,
I know:
time = ? in seconds
Thanks
Rich
This calculation would require the use of special relativity. Do you kno wsome special relativity? (if you use the non-relativistic kinematic equations with an acceleration of 9.8 m/s^2, you will end up having a spacecraft moving faster than the speed of light, which is unphysical).
Yeah I guess it does. I didn't look at the numbers that closely. You can find relativistic equations of motion in the same thread I posted earlier I think.
Space to work out this problem.
I'll try to work this out, It might take a while though. :smile:
Things I know:
c = 299,792,458m/s
c^2 = 89,875,517,873,681,800m/s
a = 9.8m/s/s
Things I might have to work out:
[tex]\gamma = \frac{1}{\sqrt{1 - v^2/c^2}}[/tex]
My Brain Hurts, this as far as I go tonight, I'll try again tomorrow.
  • · Replies 18 ·
  • · Replies 86 ·
9K
  • · Replies 18 ·
