Location of new mass when added to grav system
  • Context: Graduate
  • Thread starter Thread starter Steve Harris
    Mass System
The discussion revolves around the implications of adding mass to a gravitational system, specifically when a mass is raised in a gravitational field and the associated energy is introduced. Participants explore the relationship between gravitational potential energy and mass, questioning how energy is allocated within the system and whether it contributes solely to the raised mass or if it can be distributed elsewhere, such as in the gravitational field or the Earth itself. The conversation touches on concepts from general relativity and comparisons with electromagnetic systems.
  • Some participants argue that in general relativity (GR), the gravitational potential energy used to raise a mass does not contribute to the 'rest' mass of that mass, suggesting that GR does not locally conserve energy.
  • Others propose that while GR does not assign a specific location to energy, alternative gravitational theories might assume otherwise.
  • One participant highlights the concept of Komar mass, suggesting that it changes with height in a static system, but notes that this does not apply universally across all mass definitions in GR.
  • There is a discussion about the mass of bound states, such as a hydrogen atom, being less than the sum of its constituent particles, with some participants asserting that this reflects system-wide energy considerations rather than individual particle mass changes.
  • Concerns are raised about the credibility of sources in Wikipedia discussions, particularly regarding claims made by individuals without proper citations or authority.
  • Some participants express frustration over the difficulty of convincing others of their viewpoints, especially when faced with claims from individuals citing their own qualifications.
Participants do not reach consensus on the allocation of energy and mass in gravitational systems. There are competing views on whether the added energy contributes solely to the raised mass or if it can be distributed across the system. The discussion remains unresolved with multiple perspectives presented.
Participants note that energy conservation in general relativity is complex and that assigning specific locations to energy or mass is not straightforward. The discussion also reflects on the challenges of engaging with non-standard theories and the implications of authority in scientific discourse.
Steve Harris
Hi, Folks
I'm embroiled in a discussion on the TALK page for the Wikipedia article "E=mc2".
In this wikipedia article (Wiki), somebody has claimed that when a mass (OBJECT) of mass M is raised in a g field by a height h, adding energy M*g*h from outside the system, that the energy shows up as extra mass in the OBJECT. We all agree the mass-energy has to show up in the system. But this guy claims it all goes physically to the OBJECT raised, which alone gains mass, and he has some French physics article cite to "prove" it. I personally think it's baloney, but I'm not a physicist nor an authority. I personally think that extra mass-energy added is hard to locate physically in such situations, and could as easily be in the Earth or the gravitational field. Does modern physics speak authoritatively on this point, and (more importantly) can somebody give me a reference?
I'm not even sure that the case for a g-field is not different from that for an electrical field. If two attracting charges are separated, the work involved goes into electric field, and the mass increase to the system can be tracked as some kind of integral over the total field strength, yes? Since electric fields have definable energy/volume (unlike g fields). And yet particles (or collections of particles) are partly given their mass by their fields (as in an atomic nucleus, which masses less than the sum of the free masses of the particles composing it). We don't need to take this to mean that all those nucleons each has a slightly lesser mass, just because the collection of them does. Do we?
Steve Harris
sbharris1@earthlink.net
In GR the gravitational potential energy used in raising a body is NOT added to the 'rest' mass of the body. In that sense GR does not locally conserve energy.
However, various theories do make this assumption, but they are non-standard alternative gravitational theories such as is described http://en.wikipedia.org/wiki/Self_creation_cosmology .
As far as charged particles such as an electron and proton are concerned the bound state, a hydrogen HI atom, has less 'rest' mass than the free state.
Mass of electron = 9.1 x 10-28gm.
Mass of proton = 1.67266 x 10-24gm.
Free state: mass of proton + mass of electron = 1.67357 x 10-24gm
Bound state: mass of HI atom = 1.67352 x 10-24gm
Garth
If one has a static system, one probably could say that the Komar mass of the ball changes with its height (as the redshift factor changes) - see for instance http://en.wikipedia.org/wiki/Komar_mass
This is specific to the concept of Komar mass, though, and wouldn't apply to other important sorts of mass in GR, such as the ADM mass. In general, you are right in saying that one can't assign a particular location to energy in GR (which implies that one can't assign a particular location to mass, either).
see for instance the wiki article "mass in general relativity"
Unfortunately, energy conservation in general relativity turns out to be much less straightforward than it is in other theories of physics. In other classical theories, such as Newtonian gravity, electromagnetism, and hydrodynamics, it is possible to assign a definite value of energy density to fields. For instance, the energy density of an electric field E can be considered to be 1/2 ε0 E2.
This is not the case in general relativity. It turns out to be impossible in general to assign a definite location to "gravitational energy". (Misner et al, 1973 chapter 20 section 4).
also
http://www.physics.ucla.edu/~cwp/articles/noether.asg/noether.html
makes much the same point.
So I would say that it is wrong to assign the mass to the ball in such an unqualified manner, this assignment does not work in general, only in the special case of a static system.
Garth
Thanks, Garth. I understand an H atom has less mass than the proton or the electron. But this person essentially asserts that all the lost mass is to be attributed to loss of mass of the electron, in effect. I'm asserting that it's a system loss. In an EM system (like an atom), the loss is localized to the EM field between the particles. In a grav system, you can't even do that well, for reasons well laid out by Pervect. Steve
see for instance the wiki article "mass in general relativity"also
Thanks. I read the article and quoted it in the TALK page, but it had no effect. This person claims to have their own private Ph.D. telling them they are right that ONE raised mass in a system gains all the mass when energy is added to a grav potential, and they simply shrug off my attempts to explain that it's not so, as being anti-authority. As though their own misquoted authorities and anonymous authorities trump mine. Wikipedia really has credibility and citation problems, as you may know from JIMBO's talk page. Anyway, you might put in a visit to the E=mc2 TALK page to help, but I doubt anybody signing in as PERVECT, no matter how much GR math they may know, is going to make much difference. Thanks again for your input again, however. Steve
I would hope that not many Wikipedians would buy into the "private PHD" argument as a credible source. If they do, you might gently point them at WP:Verifiability.
So, would it be better if I changed my handle to Aahz? :-)
I just looked up Paul Marmet. If
http://www.Newtonphysics.on.ca/BIGBANG/Bigbang.html
is a sample of his work, I am *not* impressed.
I'm not terribly active on Wikipedia anymore, so I'd suggest you talk to some of the physics regulars (if they are still around, I haven't been around much recently), like Pjacobi, Ed Schaeffer, and Mpatel as far as how to handle this particular individual.
