Calculating the Rate of Change for Two Moving Cars
  • Thread starter Thread starter afcwestwarrior
    Car Related rates
The discussion revolves around calculating the rate of change of distance between two cars moving at different speeds from the same starting point. One car travels south at 60 mi/h and the other west at 25 mi/h. Participants are trying to determine how to approach the problem using calculus and the Pythagorean theorem.
  • Mixed
  • Participants explore the use of the Pythagorean theorem to find the distance between the cars and discuss the need to differentiate to find the rate of change of that distance. There are questions about the correct application of derivatives and the variables involved.
The conversation includes various attempts to apply calculus concepts, particularly differentiation, to solve the problem. Some participants express confusion about the differentiation process and the correct interpretation of the variables involved. There is no clear consensus on the correct method yet, as multiple interpretations are being explored.
Participants are working under the constraints of a homework problem, which may limit the information available for solving the problem. There are indications of misunderstanding regarding the application of calculus to the Pythagorean theorem and the interpretation of the question.
afcwestwarrior
2 cars start moving from the same point. one travels south at 60 mi/h and the other travelks west at 25 mi/h. at what rate is the distance between the cars increasing 2 hourse later.
What do i do. I need help some serious help with this one.
what equation do i use
Pythagoras Theorem A^2+B^2=C^2
ok, so i put 60^2+25^2=c^ which equals 4225
then i square root 4225 and i get 65 which is the answer in my book, thanks man if this is the right way to do it
NO you have to do the dy/dx to get the incresing speed!
whats the dy/dx is it 2
ok so i have to find the derivative of he P.T which is 2c=2a+2b
And put the dy/dx on it dc/dt(2c) = da/dt(2a)+db/dt(2b)!
but you have to calculate how much have they both travel in 2 hour and put into the equation and solve!
ok so is this what it will look like c=2*60+2*25
NO you have to calculate how much have they both travel in 2 hour
dy/dx is the speed a b and c is distance~!
so in 2 hours 60mi/h is 120 mi and 25 is 50 mi
yep , and plug the speed and the distance into equation and solve and the third distance between you have to calculate that too. use the Pythagoras Theorem you have already found up there!
so the distance is 170 mi
so what would it look like
would it look like this 2c=2*60+2*25
2c=170
c=170/2
I am starting to wonder if you are serious! You cannot differentiate c2= a2+ b2 and get 2c= 2a+ 2b. For one thing, you have completely left out the question of which variable you are differentiating with respect to. Here the question is about how fast the distance between them, c, is increasing so you are trying to find dc/dt,, not c.
As yaho8888 alrready told you, you need to differentiate both sides of c2= a2+ b2 with respect to x! Using the chain rule, that is 2c dc/dt= 2a da/dt+ 2b db/dt. Now what are a, b, c, da/dt, and db/dt after two hours?
(And c, the distance between the cars after 2 hours, is NOT 170 miles.
NO!
you have to solve for dc/dt~!
The question ask you for speed! dx/dy means speed remember that.
first solve the distance between a and b in two hours use Pythagoras Theorem.
(2*60mi/hr)^2+(2*25mi/hr)^2= c^2
if you calculate that out c = 130miles
you found the c plug into the equation~!
dc/dt(2*130miles) = (60mi/hr)*(2*120mi) +(25mi/hr)*(2*50mi)
then just solve for dc/dt~!
which is 65mile/hr!
oh, i thought i had to differentiate the pythagorean theorem.
thanks man, how come when i plug in 25^+60^2=4225 square root of 4225 i get the same answer
Man you have no Idea what calculus is!
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 24 ·
9K
