Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > Differential Equations
Reply
image second order homogenous with variable coeffecients Share It Thread Tools Search this Thread image
Old Mar15-07, 07:19 PM                  #1
Terilien
Terilien is Offline:
In general how do we deal with linear second order differential equations with variable coeffecients?
Old Mar16-07, 02:15 PM       Last edited by Matthew Rodman; Mar16-07 at 02:18 PM..            #2
Matthew Rodman
Matthew Rodman is Offline:
In general, you can't. You have to specify the form of those coefficients and hope to match it to an equation for which there is a known solution, probably involving a substitution or two along the way. (Unless it lends itself to direct integration, or something.)
Which equation are you concerned with?
Old Mar16-07, 03:21 PM       Last edited by Terilien; Mar16-07 at 03:25 PM..            #3
Terilien
why can't you just plug in in e^rt like you do with the constant coefficient ones and just let r be variable(guessing)? For example when you plug e^rt into the homogenous equation you can find r by solving a quadratic equation involving the coffecient. You need to solve for r. however since in this case the coeeficients depend on time, can't we just have variable solutions (r). note that I haven't thought about this much.
I was just curious as the notes I found didn't discuss them much.
Old Mar16-07, 03:47 PM       Last edited by Matthew Rodman; Mar16-07 at 03:54 PM..            #4
Matthew Rodman
Let's say your equation is
LaTeX Code: y^{\\prime \\prime} + \\alpha(t) y^{\\prime} + \\beta(t) y = 0
where alpha and beta are arbitrary functions. Now, try your method of subbing
LaTeX Code: y(t) = e^{r(t)}
bung this into the first equation, and you get
LaTeX Code: r^{\\prime \\prime} e^{r(t)} + r^{\\prime 2} e^{r(t)} + \\alpha(t) r^{\\prime} e^{r(t)} + \\beta(t) e^{r(t)} = 0
Now, divide out the expoenents, and your equation becomes
LaTeX Code: r^{\\prime \\prime} + r^{\\prime 2}+\\alpha(t) r^{\\prime} +\\beta(t) =0
So, you now have a different equation, but, more than likely it's not one which is any easier to solve-- unless you get lucky.
Note however, this new one is effectively a first order equation -- i.e. by letting LaTeX Code: q(t) =r^{\\prime}(t) .
Old Mar16-07, 04:03 PM                  #5
Matthew Rodman
Err... if you want ot find out what kind of second-order equations are soluble, you can look here. They also have some solutions of PDEs on other pages.
Old Mar17-07, 12:10 PM                  #6
HallsofIvy
PF Mentor
HallsofIvy is Offline:
Typically, series solutions are used for linear differential equations with variable coefficients.
Old Mar17-07, 03:20 PM                  #7
tehno
tehno is Offline:
decomposition in series...
Is general recipe ,but sometimes such eqs can be solved explicitely and in finite ,closed form.
It depends on LaTeX Code: \\alpha(t),\\beta(t) functions coefficients involved.
Old Mar17-07, 06:08 PM                  #8
Elvex
Elvex is Offline:
The brute force method, usually a method of last resort is the method of frobenius. The problem is you'll generate infinite series solutions which rarely have a closed form. The method is necessary for laplaces equation in cylindrical and spherical coordinates.
Old Mar18-07, 06:25 PM                  #9
HallsofIvy
PF Mentor
Yes, particularly "Euler type" or "equi-potential" equations.
Strictly speaking, "Frobenius" method only applies to series expansion about regular singular points, not general series expansions.
Old Mar18-07, 07:25 PM       Last edited by ziad1985; Mar18-07 at 07:49 PM.. Reason: added something            #10
ziad1985
ziad1985 is Offline:
There is the y(x)=u(x)*v(x)...
solve for v(x), and end up with something like this u'' +(something)u=0
if your lucky enough it's an easy equation...
Edit:If the Diff Eq was this: y'' +a(x)y'+b(x)y=0
then replacing y=v(x)*u(x)
we have this :u''*v+u'(2v'+a(x)v)+u(v"+a(x)v'+b(x)v)=0
Take (2v'+a(x)v)=0 solve for v , then replace in the Eq above.
Then this is what I meant if you were lucky (v"+a(x)v'+b(x)v) should simplify into something related to v in order to solve...
image image
Reply
Thread Tools
Similar Threads for: second order homogenous with variable coeffecients
Thread Thread Starter Forum Replies Last Post
Using reduction of order for Non-Homogenous DE juice34 Calculus & Beyond 1 Apr10-08 11:31 PM
non homogenous 4th order eq harsha@iitm Differential Equations 3 Nov8-07 11:43 PM
2nd order non homogenous DE aztect Differential Equations 6 Sep9-06 12:26 PM
Higher Order Non-Homogenous ODE kape Calculus & Beyond 1 Apr20-06 03:49 AM
Help solving non homogenous second order ODEs seang Calculus & Beyond 2 Feb23-06 03:51 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
