Triple Integral - Volume Question
The discussion centers on calculating the volume of a solid bounded by the equations z = 3x² + 3y² (a circular paraboloid) and z = 6√(x² + y²) (a cone). The intersection occurs at z = 12, leading to a circular region in the xy-plane with a radius of 2. The correct setup for the triple integral involves integrating in cylindrical coordinates, with θ ranging from 0 to 2π and r from 0 to 2. The z bounds are defined by the two functions, transitioning from the paraboloid to the cone.
  • Understanding of triple integrals in calculus
  • Familiarity with cylindrical coordinates
  • Knowledge of the equations of a paraboloid and a cone
  • Ability to solve for intersection points in multivariable functions
  • Learn how to convert Cartesian coordinates to cylindrical coordinates
  • Study the application of triple integrals in volume calculations
  • Explore the concept of Jacobians in coordinate transformations
  • Practice solving similar volume problems using different bounding surfaces
Students studying multivariable calculus, particularly those focusing on integration techniques and volume calculations in three-dimensional space.
twiztidmxcn
So my question is as follows: Find the volume of the solid bounded by z = 3x^2 + 3y^2 and z = 6sqrt(x^2 + y^2)
I drew the graphs of these out, with the z = 3x^2 + 3y^2 being a circular paraboloid w/ vertex at (0,0,0) and extending in positive z direction.
The z = 6sqrt(x^2+y^2) is a cone centered on the z axis w/ vertex at (0,0,0).
I started by solving z = 6sqrt(x^2+y^2) for x^2 + y^2 and then plugging that into my other z = function and got that they intersect at z = 12. After plugging 12 in for z in the equations, i got both of them x^2 + y^2 = 4.
Circle, radius 2.
So, when setting up my triple integral, I have the triple integral of dzdydx. I believe my bounds on x are -2 -> 2.
Now, for my y bounds, I just solved the x^2 + y^2 = 4 for y, found that y = sqrt(4-x^2). I figured since it was a circular figure at this point, the y bounds are -sqrt(4-x^2) -> sqrt(4-x^2).
For my z bounds, I figured that it went from the lower function to the higher function, so from 3x^2 + 3y^2 -> 6sqrt(x^2+y^2).
My question comes to this...is any of this right at all? How do I actually integrate this?
I know I am going to need to probably change it into cylindrical coordinates, but then I run into the problem of how do I find my r integration bounds...
I know this is probably a jumble, but it's what I've got and hopefully some light can be shed on this.
thanks
-twiztidmxcn
Yes, that's correct.
Circle, radius 2.
Good. In other words, if you project the entire region into the xy-plane, it covers a circle of radius 2 and your integral must cover all of that.
Good. That's correct.
Yes, that's also correct.
It would probably have been easier to set up the integral in cylindrical coordinates from the start. Your figure, projected to the xy-plane forms a circle with center at (0,0) and radius 2. To cover that, take [itex]\theta[/itex] ranging from 0 to [itex]2\pi[/itex], r ranging from 0 to 2. Now express the bounds on z in terms of r and [itex]\theta[/itex].
thanks
-twiztidmxcn
Actually, it's very well done and clear.
  • · Replies 21 ·
