How Does Drag Force Relate to Newton's Laws of Motion?
The discussion revolves around the relationship between drag force and Newton's laws of motion, specifically focusing on the equation of motion involving drag. The original poster seeks clarification on the derivation of terminal velocity and the associated differential equation.
  • Participants discuss the equation of motion, questioning how to solve it and the implications of drag force. There are inquiries about necessary mathematical concepts, such as integration and differential equations, and whether additional topics need to be learned. Some participants suggest methods for integration and substitution.
The discussion is active, with participants exploring various mathematical approaches and clarifying concepts related to differential equations. Some guidance has been offered regarding integration techniques, but there is no explicit consensus on the best path forward.
Some participants express uncertainty about their current knowledge of integration and differential equations, indicating a potential gap in understanding necessary for solving the problem. There are references to specific mathematical techniques that may not yet be familiar to all participants.
Mag|cK
Hello, please help me I have a question regarding drag force and Newton's law of motion.
This is quotes from online pdf files from University of Toronto Scarborough.
"the terminal velocity is F/b , where b is drag constant
Let’s solve the equation of motion and see how
this is reflected in the solution. Newton's law
reads
m (dv(t)/dt) = F - b v(t)
which we have written entirely in terms of the
velocity v(t) and its first derivative.
How to solve this? Well, if F were zero, we
would have dv/dt=–(b/m)v, which has its solution
some constant times exp(-bt/m). By inspection,
we find that we can account for nonzero F by
simply adding a constant, F/b. That is,
v(t) = F/b + (constant)exp(-bt/m)
Now what i don't understand is the last paragraph, and where the last equation came from. Can anyone explain more clearly? Please help :smile: Thank you very much.
A clue: http://www.sosmath.com/diffeq/first/lineareq/lineareq.html" .
Thx for the reply.
Hmm, i am still in high school, but already learned differential and integration. Do i need to learn first about something i don't learn in high school?
If so what is the topic title? Or maybe u can teach me if its possible?
thx
Mag|cK said:
Thx for the reply.
thx
Have you learned the method of substitution for integration?
i don't think so. Is there any websites that teach that?
thx
thx
Another question: do you know how to find
[tex]\int \frac{1}{x} dx?[/tex]
It seems you already know the solution to the simplest type of diff.equations, that is the one of the type: du/dt=ku, having u(t)=Ae^(kt) as its general solution.
Now, ask yourself:
What would be the next simplest type of a solution to a diff.eq?
At least my intuition says this would be a function of the form:
[tex]U(t)=A+Be^{kt}[/tex], where A,B and k are constants.
Let us see what sort of differential equation such a function satisfies!
1. We have that [itex]\frac{dU}{dt}=kBe^{kt}[/itex]
2. We can convert the right-hand side of 1. into an expression involving U itself as follows:
[tex]U=A+Be^{kt}\to{B}e^{kt}=U-A[/tex]
3. Thus, we may insert 2. into 1, and gain:
[tex]\frac{dU}{dt}=k(U-A)=C+kU, C=-kA[/tex]
4. Note that our equation 3 is a DIFFERENTIAL equation of the general form:
[tex]\frac{dU}{dt}=A+BU[/tex]
But conversely, this ought to entail that we now can SOLVE such diff.eqs, gaining solutions similar to the function we studied in 1.-3.!
We'll see that this is indeed the case:
We may rewrite 4. as:
[tex]\frac{dU}{dt}=B(\frac{A}{B}+U)[/tex]
Now, let us define a new function: [tex]Y(t)=\frac{A}{B}+U[/tex]
Now, note that by differentiation, we have the identity: [itex]\frac{dY}{dt}=\frac{dU}{dt}[/itex]
Thus, reconverting our diff.eq in terms of Y, rather than U, we get:
[tex]\frac{dY}{dt}=BY\to{Y}(t)=Ce^{Bt}\to{U}(t)=Y(t)-\frac{A}{B}=Ce^{Bt}-\frac{A}{B}[/tex]
and we see that this is a solution of the form described in 1.-3.
yes, ln x + c
"It seems you already know the solution to the simplest type of diff.equations, that is the one of the type: du/dt=ku, having u(t)=Ae^(kt) as its general solution."
Arildno, No i haven't known that :frown:
Your equation is
m dv/dt = F - b v.
Proceeding very informally, treat dv as one symbol, and dt as another. First, divide both sides of the above, by the right side of the above, and then multiply both sides dt.
What do you get?
If you haven't yet done differentiation and integration of exponentials, logs, trig function etc, yet you are getting a little bit ahead of yourself with this equation.
Not that any of those topics are "hard", but there is a far amount of detail to remember, so you have to start somewhere and take it one step at a time. Most differential equations in physics, biology, etc involve exponentials and trig functions, so it makes sense for your courses to leave the topic of "differential equations" till after you have done integration and differentiation of those functions.
George Jones said:
Your equation is
m dv/dt = F - b v.
What do you get?
(m dv)/(F - bv)=dt
Btw, is there any program downloads from the internet specially made to write mathematical equations that i can easily put on microsoft word or other applications?
There is http://www.latex-project.org/" , the engine this forum uses to format mathematics. You can't put equations into Word with it, but you can generate documents separately.
Mag|cK said:
(m dv)/(F - bv)=dt
Let v_0 be the speed of the particle at time t_0, and v be the speed of the particle at time t. Tkake this into account by integrating: (over v) the right side of the above equation from v = v_0 to v = v; the left side from t = t_0 to t = t.
[tex]\int_{v_0}^v \frac{m}{F - bv} dv = \int_{t_0}^{t} dt[/tex]
Can you do these integrations? Remember, m, F, and b are constants.
i haven't learned that kind of integration. :frown: is there any website that can teach me that?
Let's look at
[tex]\int \frac{m}{F - bv} dv.[/tex]
The denominator is a bit messy, thus set u = F - bv, so u is function v. Find du/dv and rearrange this to find dv. In the the integral, substitute u for the denominator, and also substitute for dv.
What does the integral look like now?
George Jones said:
Let's look at
is F constant? I come up with -(m/b) ln u +c
Mag|cK said:
is F constant?
For consistency, all the terms in
m dv/dt = F - b v
must have the same units. Since the right side has the units of force, both F and bv must have units of force. F is a constant force, like the force of gravity on a particle near the Earth's surface.
Good.
Now change the u back to F - bv and evaluate the resulting expression at the endpoints of the integration interval.
I haven't learned about definite integral or integration intervals. I'll come back after i learned it. Thx a lot!
Suppose
[tex]\int f \left( x \right) dx = F \left( x \right) + c.[/tex]
Then,
[tex]\int_a^b f \left( x \right) dx = F \left( b \right) - F \left( a \right).[/tex]
Geometrically, this is the area bounded by the curve f(x), the vertical lines x = a and x = b, and the x-axis.
Example: [itex]f \left(x \right) = x^2.[/itex]
[tex]\int_2^5 x^2 dx = \frac{5^3}{3} - \frac{2^3}{3} = 39.[/tex]
well then how to transform -(m/b) ln u +c into integrals with intervals. We just got rid of the integrals right?
After replacing [itex]u[/itex], we have
[tex]\int \frac{m}{F - bv} dv = - \frac{m}{b} ln \left( F - bv \right) + c.[/tex]
  • · Replies 27 ·
  • · Replies 24 ·
  • · Replies 42 ·
