What is the derivation of the identity (dS/dV)T=(dP/dT)V in thermodynamics?
  • Thread starter Thread starter pivoxa15
    Identity
The discussion revolves around the derivation of the identity (dS/dV)T=(dP/dT)V in thermodynamics, specifically relating to the concepts of exact differentials and thermodynamic potentials. The original poster expresses confusion about how this identity is derived from the fundamental thermodynamic equation dU=TdS-PdV.
  • Participants explore the relationship between thermodynamic potentials, particularly the Helmholtz function, and the identity in question. They discuss the application of Clairaut's theorem and the use of differential forms to understand the derivation. Questions arise about the notation used, such as the wedge product, and its implications in the context of partial derivatives.
The discussion is active with participants sharing insights about the use of thermodynamic functions and the properties of differentials. Some participants have offered guidance on how to approach the derivation using differential forms, while others express confusion about the mathematical notation and concepts involved.
There is a noted lack of explicit references to the Helmholtz function in the original problem statement, which some participants find challenging. The discussion also highlights the complexity of the mathematical notation, particularly regarding the wedge product and its interpretation in thermodynamics.
pivoxa15
If dU=TdS-PdV then
(dS/dV)T=(dP/dT)V
the T and V at the end means that T and V are constant
How did they get this identity? It came from a thermodynamics hence for their notations.
I have tried ways like rearranging but it doesn't seem to work. I think it has something to do with exact differentials.
Are you familiar with the Helmholtz function?
by Clairaut's theorem,
let [itex]z=z(x,y)[/tex]<br /> [tex]\left ( \frac{\partial^2 z}{\partial x\partial y}\right )=\left ( \frac{\partial^2 z}{\partial y\partial x}\right )[/tex]<br /> <br /> or more explicitly, using "thermodynamic notations":<br /> [tex]\left [\frac{\partial}{\partial y}\left ( \frac{\partial z}{\partial x}\right )_y\right ]_x=\left [\frac{\partial}{\partial x}\left ( \frac{\partial z}{\partial y}\right )_x\right ]_y[/tex]<br /> <br /> then look at:<br /> [tex]F=U-TS[/tex]<br /> <br /> [tex]dF=-SdT-PdV[/tex]<br /> so F is a function of T and V, ie. [itex]F=F(T,V)[/tex] (when N is treated as a constant)[/itex][/itex]
I see. The Clairaut's theorem is a formal way of stating exact differentials isn't it?
Helmholtz function is F=U-TS and sub dU=TdS-PdV and apply Clairaut's theorem.
Using F=U-TS was the important bit. The sheet didn't mention Helmoholtz anywhere so it would have been hard to know what to use in order to derive the relation. Wouldn't you say?
not really.. hehe, looking at the derivatives you posted. One easily notice that the variables involved are V and T.
so you should know the one thermodynamic potential that is a function of V and T. (which is F)
in general, you have
U(S,V)
H(S,P)
F(T,V)
G(T,P)
H=U+PV
F=U-TS
G=U-TS+PV
so when you see an identity, check what variables it involves and use the appropriate thermodynamic functions.
There's a neat calculation involving differential forms.
[tex]0=d(dU)=d(TdS-PdV)=dT \wedge dS+Td(dS) - dP\wedge dV-Pd(dV)=dT\wedge dS-dP\wedge dV[/tex]
Then write
[tex]dS=\left(\frac{\partial S}{\partial T}\right)_V dT + \left(\frac{\partial S}{\partial V}\right)_T dV[/tex]
and
[tex]dP=\left(\frac{\partial P}{\partial T}\right)_V dT + \left(\frac{\partial P}{\partial V}\right)_T dV[/tex].
Note that [tex]dT\wedge dT=0[/tex] and [tex]dT\wedge dV= - dV\wedge dT[/tex].
U(S,V)
H(S,P)
F(T,V)
G(T,P)
H=U+PV
F=U-TS
G=U-TS+PV
OK. But you could interchange these functions couldn't you to get them into different variables intermingled together.
[tex]0=d(dU)=d(TdS-PdV)=dT \wedge dS+Td(dS) - dP\wedge dV-Pd(dU)=dT\wedge dS-dP\wedge dV[/tex]
Then write
and
What is the upside down V in the equations?
the notation looks insane.
just one question, why does d(dU)=0??
and I am very confused by the info from mathworld...
so
[tex]dT\wedge dS[/tex]
equals what in terms of partial derivatives?
is it like a vector cross product or something like that?
suppose a=a(x,y), b=b(x,y)
what would
[tex]da\wedge db[/tex]
be?
This comes from the definition of the exterior derivative
so
Plug dS and dP into the first equation in robphy's post.
what would
be?
Look up the exterior derivative above.
wow.. thanks for the info. differential forms are awesome! time for me to pick up a book on such topic.
30K
