Convergence of Alternating Series with Tricky Terms
The forum discussion focuses on testing the convergence of two specific series using the Alternating Series test. The first series, sum of (-1)^n * n/(ln n), diverges because the limit of n/(ln n) approaches infinity, failing the test's requirement that the terms must approach zero. The second series, sum of [sin(n*pi/2)]/n!, can be analyzed by recognizing its relationship to the Taylor series for sine, leading to a convergent form of 1/sqrt(2) * sum of 1/(2n+1)!. The discussion emphasizes the importance of recognizing the behavior of series terms and applying the Alternating Series test correctly.
  • Understanding of the Alternating Series test
  • Familiarity with Taylor series expansions
  • Knowledge of limits and their implications in series convergence
  • Basic concepts of factorial notation and convergence criteria
  • Study the Alternating Series test in detail to understand its conditions
  • Learn about Taylor series and their applications in convergence analysis
  • Explore the behavior of logarithmic functions in limits
  • Investigate convergence tests for series, including the Ratio Test and Root Test
Students and educators in calculus, mathematicians analyzing series convergence, and anyone interested in advanced mathematical series and convergence tests.
Gauss177
Test the series for convergence or divergence using the Alternating Series test:
1. sum of (-1)^n * n/(ln n)
2. sum of [sin(n*pi/2)]/n!
1. lim of n/(ln n) goes to infinity (as n->infinity), so it can't satisfy the Alternating Series test. Then if I take limit of the entire sum, I can't figure out what it comes to. I think the limit doesn't exist so the whole thing is divergent, but I'm not sure how to get it.
2. No clue on this one, it's not in the "proper format" as the examples I've seen.
Thanks
1. See if the taylor series for ln x helps.
2. Consider the terms of this series in pairs, n=0,1. What do you notice with the sin part?
EDIT: More clues, because i want to be generous :D
Whats zero divided by anything (other than zero)? You should be able to get that sum to now look like
[tex]\frac{1}{\sqrt{2}} \sum_{n=0}^{\infty} \frac{1}{(2n+1)!}[/tex] Does that converge :)?
1. One of the first things you learn about series is that if an does NOT go to 0, then [itex]\Sigma a_n[/itex] does NOT converge.
2. Is this an alternating series? What is the "alternating series test"?
