Thread Closed
Frequency of Generator + V of Capacitor
Share Thread Thread Tools
Mar19-07, 09:10 AM   #1
[b]1. A 8.6 Hz generator is connected to a capacitor. If the current in the generator has its maximum value at t=0 s, what is the earliest possible time that the voltage magnitude across the capacitor is at a maximum?
[b]2. I'm actually not sure which equations are relevant for this problem!
[b]3. I'm afraid I don't understand the concepts behind this problem. I read in my book about oscillations in an LC circuit with no generator, but then I don't understand how this can be applied when there *is* a generator with its own frequency. Any help would be appreciated!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Mar19-07, 09:25 AM   #2
Recognitions:
Gold Membership Gold Member
It depends on the waveform of the generator. If we assume sinusoidal then the voltage from the generator is V*cos(2*pi*8.6*t) which has its maximum V when t=0 as required. Find the formula that tells you how a capacitor charges and you're halfway there.
Mar19-07, 10:13 AM   #3
Mentor
Quote by Mentz114 View Post
Except the problem statement says that the current is max at t=0, not the voltage. kmj9k, what is the relationship between voltage and current in a capacitor? Assume a sinusoidal waveform along the lines of what Mentz suggested....will the current lead or lag the voltage in a capacitor?
Thread Closed
Thread Tools
Similar Threads for: Frequency of Generator + V of Capacitor
Thread Forum Replies
converting frequency to current for an ac generator Electrical Engineering 4
Parallel RLC circuit: find resonant frequency and Input at that frequency Introductory Physics Homework 7
Frequency Generator for Hydrogen System Electrical Engineering 4
High frequency quadrature signal generator Electrical Engineering 1
Capacitor behavior over frequency Electrical Engineering 7
