Solve Integration Problem: \int_{1}^{2}(\frac{2}{2x+1})^3 dx
  • Thread starter Thread starter disregardthat
    Integration
The problem involves evaluating the definite integral \(\int_{1}^{2}(\frac{2}{2x+1})^3 dx\), which falls under the subject area of calculus, specifically integration techniques.
  • Participants discuss the substitution method, particularly the need to correctly express \(dx\) in terms of \(du\) when using \(u=2x+1\). There are questions about the proper setup of the integral after substitution and the implications of including the derivative in the substitution process.
Participants are actively clarifying the steps involved in the substitution method. Some have offered guidance on ensuring the correct form of the integral after substitution, while others are exploring how to handle the derivative and its impact on the integral setup.
There is an ongoing discussion about the implications of missing factors in the integral due to the substitution process, and participants are questioning their understanding of the relationship between \(du\) and \(dx\).
disregardthat
[tex]\int_{1}^{2}(\frac{2}{2x+1})^3 dx[/tex]
Normal integral equations
[tex]\int_{1}^{2}(\frac{2}{2x+1})^3 dx = 2^3\int_{1}^{2}\frac{1}{(2x+1)^3} dx[/tex]
u=2x+1
[tex]2^3\int_{1}^{2}\frac{1}{u^3} dx = 2^3\int_{1}^{2}u^{-3} dx[/tex]
Antiderivate of [tex]u^{-3} = \frac{u^{-3+1}}{-3+1} = \frac{u^{-2}}{-2}= \frac{1}{-2u^2}[/tex]
Plotting the real u in: [tex]\frac{1}{-2(2x+1)^2}[/tex]
[tex]2^3\int_{1}^{2}\frac{1}{-2(2x+1)^2} = 2^3\left(\frac{1}{-2(2x+1)^2}\right)_1^2 =2^3\left(\frac{1}{-2(2 \cdot 2+1)^2}\right) - 2^3\left(\frac{1}{-2(2 \cdot 1+1)^2}\right) = \left(\frac{2^3}{-50}\right) - \left(\frac{2^3}{-18}\right)[/tex]
[tex]= \left(\frac{72}{-450}\right) - \left(\frac{200}{-450}\right) = \left(\frac{72-200}{-450}\right) = \left(\frac{-128}{-450}\right) = \frac{128}{450} = \frac{64}{225}[/tex]
This gives about: 0.284444...
When I type this function on the calculator, the area between x=1 and x=2 is 0.1422222...
That is half of my answer, what have I done wrong?
u=2x+1
du=2dx
you need u du not u dx up there in your substitution.
So you have to divide by 2 outside the integral.
I see, I have to divide by two.
But i did not understand why.
EDIT: I mean, how do you find du?
Hey,
It's just the derivative of 2x+1 with respect to x, which is 2 dx. You always need to find du when you use the u substitution.
All right.
So how am I to set it up then?
[tex]\int_{1}^{2}(\frac{2}{2x+1})^3 dx =[/tex]
Any of these?
[tex]\frac{d}{dx}2^3\int_{1}^{2}\frac{1}{(u)^3} dx[/tex]
[tex]\frac{2^3}{du}\int_{1}^{2}\frac{1}{(u)^3} dx[/tex]
Do you have an example of an solution to a task like this? I want to know how you should set up the solution so I see what is really going on.
Hi,
u=2x+1
du=2dx
[tex]\frac{2^3}{2}\int_{1}^{2}\frac{1}{u^3} du = \frac{2^3}{2}\int_{1}^{2}u^{-3} du[/tex]
You just have to make sure that you've got [tex]u du[/tex] not [tex]u dx[/tex]. The derivative of the u=2x+1 has to be included. You don't want an extra 2 in there, so you just divide it out. That's all. You integrated this perfectly, just missed the du substitution.
Hope this helps.
CC
or maybe more clear
u=2x+1
du=2dx
[tex]\frac{1}{2}du=dx[/tex]
then factor out the 1/2.
Oh, right. So when I now have the du after the u^-3 then I just antiderivate just like before right?
the du in the end doesn't have any meaning to how I am supposed to antiderivate the function, right? Without of course the division of 2^3.
Uhm, I mean:
When you have a function, and use substition, you have to find the derivative of the substibtution and then divide the function with it, (it is enough to divide the 2^3) and then just antiderivate as before, only with a du instead of dx. Is that correct?
And should the du at the end stand there until i have antiderivated u or when i put 2x+1 back again?
Correct. When you integrate, the du goes away. Then you put back in your u, just as you did.
All right, thanks for your help
  • · Replies 105 ·
13K
