Length of Curve: Find \int_{0}^{1} (3x^3+11x) dx
  • Thread starter Thread starter Aerosion
    Curve Length
The discussion focuses on calculating the arc length of the curve defined by the function y=3x^3+11x from the point (0,0) to (1,14). The correct formula for arc length is provided as S = ∫ab √(1 + (dy/dx)²) dx, where dy/dx is the derivative of the function. The user initially misapplied the integral for area under the curve instead of the arc length formula. The correct derivative, dy/dx, is calculated as 9x² + 11, which is essential for determining the arc length.
  • Understanding of calculus, specifically integration and derivatives.
  • Familiarity with the arc length formula in calculus.
  • Knowledge of the function y=3x^3+11x and its properties.
  • Ability to manipulate and evaluate definite integrals.
  • Study the derivation and application of the arc length formula in calculus.
  • Practice calculating derivatives of polynomial functions.
  • Learn how to evaluate definite integrals using numerical methods.
  • Explore additional examples of arc length calculations for different functions.
Students studying calculus, particularly those focusing on integration and arc length calculations, as well as educators looking for examples to illustrate these concepts.
Aerosion
To find the length of the curve defined by y=3x^3+11x from the point (0,0) to the point (1,14), you'd have to compute:
[tex]\int_{a}^{b} f(x) dx[/tex]
where a=?, b=? and f(x)=?
So I put a to be 0 and b to be 1, since it's asking for the x axis.
Then I took the equation y=3x^3+11x and got its derivative, 9x^2+11. I subtracted one from the entire equation and square rooted the entire thing, such that it looked like [tex]\sqrt{1-9x^2+11}[/tex].
Did I do anything wrong here? This is an internet-generated exercise I'm doing.
That will give you the area under the curve, not the arc length. Do a bit more searching for the arc length forumal.
That will not give you the area under the curve, nor will it give you the arc length!
The arc length would [tex]S = \int_a^b \sqrt{1 + (\frac{dy}{dx})^2}[/tex]
*Note that is (dy/dx)^2, I did something latex didn't like.
