How Does Momentum Transfer Relate to Spherical Symmetry in Form Factors?
The discussion revolves around the relationship between momentum transfer and spherical symmetry in form factors, particularly focusing on the mathematical representation of these concepts in the context of charge distributions.
  • The original poster attempts to understand the transition from an exponential function to a sinusoidal form in the context of integrating over a spherical symmetric charge distribution. Some participants discuss the implications of spherical symmetry on the integration process and the resulting mathematical expressions.
Participants are actively engaging with the problem, with some offering insights into the mathematical transformations involved. There is a sense of progress as one participant expresses gratitude for the assistance received, indicating a productive exchange of ideas. However, further clarification is sought by another participant, suggesting that the discussion is ongoing.
The original poster notes a missing factor in the integral and expresses confusion regarding specific mathematical transitions, indicating potential gaps in understanding that are being explored through the discussion.
malawi_glenn
I have a form factor that only depends on the momentum transfer q, this is symbolised by writing the form factor as F(B]q[/B]^2).
if i have a spherical symmetric distribution of charge, f only depends on the radius; r = | q|
Then integration over all solid angels yields:
https://www.physicsforums.com/attachment.php?attachmentid=9530&stc=1&d=1174376003
(there should be a r^2 inside the integral ;))
I do not understand how this Sinus - thing plops up.. all i know is this:
https://www.physicsforums.com/attachment.php?attachmentid=9531&stc=1&d=1174376117
I really need a hint how to go from the exponential function to this sinus thing. =/
Since f(x) is independent of the polar angles you can rotate the x coordinate system so that the q vector points along, say, the positive z-axis. So the exponential becomes exp(i*|q|*r*cos(theta)). Doing the theta integration gives you the 'sinus thing'.
thanx a lot, i will try tonight:)
it was a piece of cake now, thanks again!
Could you explain more about it?
9K
