Finding Tension and Mass in a Rotational Motion Problem
The discussion revolves around a problem in rotational motion involving a mass tied to a rope wrapped around a cylindrical drum. Participants are tasked with finding the tension in the rope and the mass of the drum, given the mass of the falling object and its acceleration.
  • Mixed
  • Participants explore the relationship between gravitational acceleration and the acceleration of the falling mass, questioning the validity of their calculations and assumptions regarding tension and mass. Some express confusion over the application of Newton's laws and torque definitions.
Several participants are actively engaging with the problem, providing insights and corrections to each other's reasoning. There is an ongoing exploration of the forces acting on the system and how they relate to the equations being used. Some guidance has been offered regarding the correct application of torque and the role of tension in the system.
Participants note potential sign errors in their calculations and the importance of establishing a consistent sign convention. There is also mention of a free body diagram being attached for clarification.
xaer04
From the text: "A [itex]50 kg[/itex] mass is tied to a massless rope wrapped around a solid cylindrical drum. The drum is mounted on a frictionless horizontal axle. When the mass is released, it falls with acceleration [itex]a = 3.7 \frac{m}{s^2}[/itex]. Find (a) the tension in the rope and (b) the mass of the drum.
Mass of the falling object = [itex]50 kg[/itex]
Acceleration of gravity = [itex]9.8 \frac{m}{s^2}[/itex]
Net acceleration of falling object = [itex]3.7 \frac{m}{s^2}[/itex]
Newton's 2nd Law
[tex]\sum \vec{F} = m \vec{a}[/tex]
definition of torque in terms of radius and Force applied
[tex]\tau = r \vec{F} \sin (\theta)[/tex]
Definition of torque in terms of rotational intertia and rotational acceleration
[tex]\tau = I \alpha[/tex]
Definition of rotational acceleration in terms of radius and tangential acceleration
[tex]\alpha = \frac{a}{r}[/tex]
Rotational intertia for a cylinder
[tex]I = \frac{1}{2} MR^2[/tex]
I know that [itex]a_\textit{gravity} - a_\textit{rope} = a_\textit{final}[/itex] for the falling block. this gave me an upward acceleration of [itex]6.1 \frac{m}{s^2}[/itex], which gave me my first answer:
[tex]T = -305N[/tex]
For my second answer, i set the definitons of torque in terms of quantities that i knew and the one quantity that i didn't know - mass of the falling object, mass of the drum, acceleration of the falling object, force of the falling object.
My equation looked like this before i started cancelling out things:
[tex](\frac{1}{2}Mr^2) (\frac {a}{r}) = (rma)[/tex]
The radius values and accelerations canceled out, leaving me with this:
[tex]M = 2m[/tex]
This can't be right because the mass of the larger object can't be entirely dependent on the mass of the smaller object. Could someone help me out?
I have not checked the numbers. However, I don't understand how you conclude that the difference between the acceleration due to gravity and the rope is equal to the final acceleration. I suggest drawing a force-body diagram. You should quickly determine what the tension is from it.
[tex]M = 2m[/tex]
Why can't that be? It is perfectly possible for the mass of the drum to be twice that of the falling mass.
Additional info
sorry about that. i attached a free body diagram. also, i posted the formula incorrectly, but the posted answer i obtained like this.
[tex]9.8 + a_\textit{rope} = 3.7[/tex]
[tex]a_\textit{rope} = -6.1[/tex]
as for my question - I predicted that the mass of the drum would be larger, but i suppose I was looking for a more complicated equation. Maybe I'm having an issue grasping that the acceleration and radius cancels out completely in my formula, because it doesn't seem plausible.
Where does this come from? Instead, write the force equation for the hanging mass per Newton's 2nd law.
ok, ok, lol... i'll write the force equation.
[tex]\sum \vec{F} = \vec{F}_\textit{gravity} + \vec{F}_\textit{rope}[/tex]
[tex]\sum \vec{F} - \vec{F}_\textit{gravity} = \vec{F}_\textit{rope}[/tex]
[tex]185N - 490N = -305N[/tex]
I opted to leave mass out and work with acceleration in the beginning for easier calculating... that didn't account for my sign error in my equation though, i just copied it wrong... unless I'm calculating for the tension incorrectly?:(
Much better. (That acceleration equation made no sense on its own.)
You are messing up the directions of the forces (and thus their signs), that's why you get a negative answer. The forces are gravity and rope tension: which way do they act? What's the direction of the acceleration? Hint: Use a consistent sign convention.
Your expression for torque--the right hand side of the equation--is incorrect.
alright... i'll have upward be positive, giving me -185 + 490 = 305 N. I don't know why i had it backwards, to be honest.
really? Are you talking about this: [itex]\tau = r \vec{F} \sin(\theta)[/itex]? I changed F to ma, and i see the point that the rope begins to hang freely as making a horizontal line with the radius, making the Force of the torque being perpendicular: so
[tex]\sin(\frac{\pi}{2}) = 1[/tex]
leaving me with r*m*a.
xaer04 said:
Are you talking about this: [itex]\tau = r \vec{F} \sin(\theta)[/itex]? I changed F to ma...
Why? The F you need is the force exerting the torque on the drum--what's that? "ma" would be the net force on the mass--not relevant.
Would the tension on the rope be the force exerting the torque on the drum?
Of course. It's the rope that pulls on the drum.
ok... so the F on the right side of my equation is 305N, and then a on the left side is 3.7m/s^2, the net acceleration of the closed system. therefore, my final equation should be like this:
[tex]M = \frac{2F_\textit{rope}}{a_\textit{net}}[/tex]
*calculating*
about 165kg. that makes a LOT more sense, heh:) So my equation was almost right, i just misunderstood what variables meant what. thank you very much, Doc Al and e(ho0n3 :) Thanks to you... i have all week to do other homework.
  • · Replies 35 ·
