A change in length ratio question
  • Context: Undergrad
  • Thread starter Thread starter X1088LoD
    Change Length Ratio
The discussion focuses on the ratio of change in length, dL/L, when a length L is stretched to a new length L+dL. Using an example where L is 2 mm and the stretched length is 2.2 mm, the ratio is calculated as 0.1. The conversation explores whether this ratio remains consistent when examining a portion of the length, specifically between 1.2 mm and 1.6 mm, concluding that under uniform stretching conditions, the ratio dL/L remains constant throughout the length due to Hooke's Law, which states that dL/L is proportional to the pressure applied along a uniform cross-section.
  • Understanding of basic mechanics principles, specifically Hooke's Law
  • Knowledge of ratios and their calculations
  • Familiarity with the concept of uniform stretching in materials
  • Basic grasp of physical properties such as pressure and cross-sectional area
  • Study the applications of Hooke's Law in material science
  • Explore the mathematical derivation of ratios in physical systems
  • Investigate the effects of non-uniform stretching on length ratios
  • Learn about tensile and compressive forces in engineering materials
Students and professionals in physics, mechanical engineering, and materials science who are interested in understanding the principles of material deformation and the application of Hooke's Law in real-world scenarios.
X1088LoD
This may be common sense, but my brain just isn't working at the moment.
If I am taking a length, L, and effectively stretching it to a new
length, L+dL. I am interested in the ratio dL/L
Let us say for example L is 2 mm long, and a stretched length of 2+0.2
mm is 2.2 mm. The total ratio of change, dL/L, is 0.2/2, or 0.1
If I take a portion of that length, let's say, between 1.2 and 1.6, and
examine only the length where L is now 0.4. If the same stretching is
applied, does the ratio of dL/L remain the same no matter where I am
looking at a portion of the length?
Thanks
Probably- yes. It depends on how you stretch the line.
Under a uniform stretch- x'=ax. dx=x'-x=(a-1) x, dx/x=a-1
If you are looking at this as a physical (Physics - Mechanics) problem then the answer is yes. A thing called Hookes Law states that dL/L is proportional to the pressure (Force per unit CrossSection) in the member. So if the member is of uniform cross-sectional area then the pressure (tensile pressure if stretching and compressive pressure if contracting) is constant along its length and therefore so is dL/L.
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 19 ·
