Integral Homework Help: Stuck on t^4+16
  • Thread starter Thread starter BrettB
    Integral Stuck
The problem involves evaluating the integral \(\int\frac{1}{t^4+16}\,dt\), which falls under the subject area of integral calculus. The original poster expresses difficulty in finding a suitable method for integration.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts various substitutions, including \(t^2 = 4u\), but encounters challenges in expressing the integral in a usable form. Participants discuss factoring the expression and using partial fractions, while some express concerns about the complexity of the resulting expressions.
Participants are actively exploring different approaches, with hints and suggestions being exchanged. There is recognition of the integral's complexity, and while some participants are attempting to clarify methods, there is no explicit consensus on a successful approach yet.
Some participants mention the potential for complex numbers in the expressions, and there is a note about the integrator providing a complicated answer involving logarithmic and inverse tangent functions. The original poster indicates this integral is the only one from a set that remains unsolved.
BrettB
[tex]\int\frac{1}{t^4+16}\,dt[/tex]
Various integration formulas. I am pretty stuck.
I have tried various substitutions, with no success. I tried t^2 = 4u, hoping to get it into the form 1/(u^2+1) so I could use the arctan formula, but then du/dt = t/2 and so I don't have an equivalent expression when I substitute.
I have tried various other substitutions with no better luck. If anyone has a suggestion, I would be so grateful. This is the only one from this set I haven't been able to solve.
Thanks!
Brett
HINT: [tex]t^4 +16=t^4 +8t^2 +16 -8t^2[/tex]
Thanks dextercioby. If I understand your hint, I would factor [tex](t^2+4)^2-8t^2[/tex] into two factors, use partial fractions, and then integrate the two expressions that would result?
That doesn't seem to work. I end up with imaginaries in the expression, unless I am doing something wrong.
I don't want to put you off- but the Integrator gives an answer that is quite complicated- involving 2 logs and 2 inverse tan functions. Could it be that you've misread the question?
I would rate this integral as tough.
Ok, I think I've got it... Wow. This is so much more complicated than any other expression. Wow.
I'm not sure if that's what dex wanted.
But either way, you're doing something wrong.
[tex]\frac{1}{t^4+16}= \frac{\frac{-t}{16\sqrt{2}} - \frac{1}{8}}{t^2 + 2\sqrt{2} +4} - \frac{\frac{1}{8} - \frac{t}{16\sqrt{2}}}{-t^2+2\sqrt{2}-4}[/tex]. Not very nice.
  • · Replies 105 ·
13K
  • · Replies 22 ·
