Calculate the acceleration of the block
The discussion revolves around calculating the acceleration of a block being slid up a chalkboard, involving forces such as applied force and friction. The subject area includes concepts from dynamics and friction in physics.
  • Participants discuss the forces acting on the block, including applied forces and friction. There are attempts to calculate the force of friction and acceleration using various formulas, with some participants questioning the definitions and roles of the forces involved.
The discussion is ongoing, with participants providing guidance on identifying forces and applying relevant formulas. There are multiple interpretations of the problem, and participants are encouraged to clarify their attempts and reasoning.
Some participants express uncertainty about the normal force and its role in calculating friction, while others emphasize the need to systematically approach the problem by identifying all forces involved.
raman911
A 0.5 kg block is being slid up a chalkboard with an applied force of 6.0 N upward and 2.0 N inward towards the board. If the coefficient of kinetic friction is 0.4.
a) Calculate the force of friction.
b) Calculate the acceleration of the block.F = mju R [ F = u R]
1. F/u = 6/0.4 = 15N ?
2. F = ma ... 6/0.5 = a = 12m/s^2
not sure... some1 back me up on this!
no one helping
If you would like help, show what you've done so far--per PF rules.
Start by identifying all the forces acting on the block.
Show us your attempts at solving this problem first.
2. (6-(2*0.4))/0.5= 10.4 upwards w.r.t board.
(6-(2*0.4)-(0.5*9.8))/0.5=0.6 upwards w.r.t ground.
I assume F is the friction force? So what is R?
sorry
mean Fn
can u help now
Seems like you have several versions of solutions. Approach it systematically: What forces act on the block? What's the force of friction?
can u help me
which formula i need to use first one
For (1), use the formula you've already stated, F=uN. Do you know what force N is in this case? (I think you were calling in R in your first post)
I AM NOT SURE
CAN U DO THAT.
N is the normal force. The block is being pushed against a vertical wall. So which of the two forces you were given in the question is holding the block on the wall? That is the force you need to use to find the force of friction.
i need help in B
raman911 said:
i need help in B
So you have finished A and correctly calculated the force of friction? If so, good.
To solve B, identify all the forces acting on the block. Then find the net force and use that to calculate the acceleration via Newton's 2nd law.
  • · Replies 33 ·
  • · Replies 45 ·
