Calculate some things about a tetrahedron
  • Thread starter Thread starter Harmony
    Tetrahedron
The discussion centers on calculating geometric properties of a tetrahedron with equilateral triangle faces, specifically focusing on the lengths and angles related to its surfaces. The tetrahedron has sides measuring 2 units. The user successfully calculated the perpendicular length from vertex A to the plane BCD and the angle between surfaces ACD and BCD, but encountered discrepancies in calculating the angle between edge AB and plane BCD. The correct angle is confirmed to be 53.1 degrees, while the user's calculation yielded approximately 54 degrees, indicating a potential rounding error in their method.
  • Understanding of tetrahedron geometry
  • Knowledge of trigonometric functions, specifically sine
  • Familiarity with calculating angles and distances in three-dimensional space
  • Ability to perform geometric proofs and calculations
  • Review the principles of tetrahedron geometry and properties
  • Study trigonometric identities and their applications in three dimensions
  • Learn about calculating angles between lines and planes in 3D geometry
  • Explore methods for minimizing rounding errors in geometric calculations
Students and professionals in mathematics, geometry enthusiasts, and anyone involved in spatial reasoning or 3D modeling will benefit from this discussion.
Harmony
Question Statement:
Each surface of a tetrahedron ABCD is an equilateral triangle with each side 2 units long. The midpoint of AB and CD are L and M respectively. Calculate, by giving your answers correct to 3 s.f. or to the nearest 0.1 degree,
a) The length of the perpendicular from A to the plane BCD
b) The angle between the surface ACD and BCD
c) Angle between AB and the plane BCD
My Attempt So Far :
I have solved part A and B. The only part that confuse me is part C.
My calculation :
let the angle between AB and the plane BCD be x.
The perpendicular distance from A to the plane BCD be p.
So sin x = p/AB = 1.63/2
But the answer given is x = 53.1 degree, which is slightly smaller than the answer I found.
Is the method I used wrong?
Just looking quickly the answer you have may be less due to rounding error. How much less is your answer than the answer given in the book?
1 degree. The answer given is 53.1 degree, wheres mine is about 54 degrees.
  • · Replies 42 ·
