Angular velocity of airplane propeller
The discussion focuses on calculating the angular acceleration and angular speed of an airplane propeller modeled as a slender rod. The propeller, measuring 2.08 m in length and weighing 117 kg, experiences a constant torque of 1950 N*m, resulting in an angular acceleration of 46.23 rad/s². To determine the angular speed after 5 revolutions, participants are advised to utilize the relationship between angular displacement and angular acceleration, drawing parallels to linear motion equations.
  • Understanding of torque and angular acceleration concepts
  • Familiarity with the moment of inertia calculation for a slender rod
  • Knowledge of angular kinematics equations
  • Basic grasp of rotational motion principles
  • Study the derivation of moment of inertia for various shapes
  • Learn about angular kinematics equations, specifically relating angular displacement to angular velocity
  • Explore the relationship between linear and angular motion
  • Investigate the effects of varying torque on angular acceleration
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of rotating systems, particularly in aviation contexts.
lollypop
here is the problem:
An airplane propeller is 2.08 m in length (from tip to tip) and
has a mass of 117 kg. When the airplane's engine is first started,
it applies a constant torque of 1950 N*m to the propeller, which starts from rest.
-What is the angular acceleration of the propeller? Treat the propeller as a slender rod.
For this part i got 46.23 rad/s^2 finding first I=(1/12)ML^2
and then plugging that into acc angular = torque/I
What is the propeller's angular speed after making 5.00 rev?
-for this part i get confused, am i supposed to use
5 rev "per min". i used the formula v = w*r where
w= 2*pi*frequency, but it is not right.
can anyone direct me to the right formula??
thanks.
Hint
Remember the problems you have solved with constant linear acceleration g? In that case, if you were asked how fast an object was moving after it had gone a certain distance, you would first use the fact that x=(1/2)gt^2 (if initial position is zero and initial velocity is zero) to solve for t, given some position x. Then you would substitute that value of t into v=gt, and you would have your answer.
The angular acceleration procedure is very much analogous.
  • · Replies 30 ·
  • · Replies 138 ·
9K
