Calculating Emitter, Base and Collector Currents in an NPN Transistor
The emitter current (IE) in the discussed NPN transistor is 8 mA, with 0.8% of the minority carriers in the base recombining with holes. The relationship IE = IB + IC is established, allowing for the calculation of the base current (IB) and collector current (IC). By substituting the values into the equation, the exact value of alpha (α) can also be determined. This discussion provides a clear method for calculating these currents in NPN transistors.
  • Understanding of NPN transistor operation
  • Familiarity with current relationships in transistors
  • Knowledge of minority carrier behavior in semiconductors
  • Basic algebra for solving equations
  • Calculate base current (IB) using the formula IB = IE * 0.008
  • Determine collector current (IC) using the equation IC = IE - IB
  • Learn about the significance of alpha (α) in transistor operation
  • Explore the effects of minority carrier recombination in semiconductor physics
Electronics students, electrical engineers, and anyone studying semiconductor devices will benefit from this discussion on calculating currents in NPN transistors.
cowgiljl
The emitter current in a certian npn transitor is 8 mA. If .8% of the minority carrier injected into the base recombing with the holes, find the base current , collector current and the exact value of alpha
i am not sure how to get this started
thanks
joe
still struggling and REALLY don't know how to go about this problem
thanks
joe
As you know IE = IB + IC
From the text I would gess that IB = 0.8% from IC, so just substitute in the first equation and you should find alpha
11K
  • · Replies 62 ·
11K
  • · Replies 60 ·
18K
