How could a spaceship mimic gravity?
  • Context: Graduate
  • Thread starter Thread starter Ara macao
    Gravity Spaceship
The discussion revolves around the concept of creating artificial gravity in a spaceship, exploring various theoretical and practical approaches to mimic gravitational effects experienced on Earth. Participants consider different methods, including centrifugal force, electromagnetic fields, and structural designs, while addressing the challenges and limitations of each approach.
  • Some participants propose using electromagnetic forces, suggesting a strong negative field combined with positively charged packs to create a gravitational effect.
  • Others argue that centrifugal force is a common solution, advocating for a spinning spaceship to simulate gravity, but raise concerns about the size required for effective gravity simulation.
  • A participant mentions inertial compensators as a potential method, though details are not elaborated.
  • Another suggestion involves continuous acceleration and deceleration to create a gravitational effect, but this is met with skepticism regarding its practicality.
  • Some participants discuss the feasibility of orbiting a celestial body, but others point out that orbiting would not create true gravity, as it involves freefall.
  • One participant speculates about creating a planet with optimal mass and distance from the sun to mimic Earth's climate, although this is presented as a hypothetical scenario.
  • Concerns are raised about the differences in gravitational force experienced at various heights within a structure, suggesting that a large design would be necessary to minimize these differences.
  • Another idea involves using a large cylinder that spins around its axis to create artificial gravity, with calculations provided for the required dimensions to achieve minimal acceleration differences.
  • Some participants express uncertainty about the practicality of their ideas, acknowledging the challenges of building large structures in space.
Participants express a range of competing views on how to effectively create artificial gravity, with no consensus reached on a single viable method. The discussion remains unresolved, with various hypotheses and concerns presented.
Participants highlight limitations related to the size and structural integrity required for different methods, as well as the dependence on specific conditions and assumptions regarding gravitational effects.
Ara macao
As we know from movies such as "Star Wars" and "Star Trek", the characters move as if they were on a planet. The question is - could there be a mimic to gravity on the spaceship? Obviously, we cannot put too much mass on a spaceship, which would make the spaceship much more inert to acceleration/deceleration. So the obvious other force is the electromagnetic force. One could envision a very strong negative field on the bottom of the field, and people wearing positively charged packs that did not mix in with the surrounding areas. We can confine charges within magnetic fields. The gravitational field and the electromagnetic field both decrease as the square of distance, so the geometries of the two fields aren't likely to be different. So the question is, is such a system possible?
Astronomy news on Phys.org
"Centrifugal force" is the usual solution to this problem. Just have the spaceship spin at a good rate, and the passengers can walk on the inside surface.
I don't think so. Because the gravity change from your hands to your feet is probably quite different. And if you'll probably jump way higher than you would on Earth. The spaceship would have to be ridiculously huge to mimic gravity on Earth using that method.
Inertial compensators, duh.
Keep accelerating...? Start decelerating at the same rate when you're halfway through.
have it orbit the moon?
That won't work. Orbit is freefall, generally.
the Earth is to close for it to work
i don't know what I'm talking about here but let me give it a shot:-p
if you put a planet into it's own independent orbit and calculated what it's optimal mass should be in relation to it's distance from the sun couldn't something be worked out where you have almost the same climate as earth? how about putting it on an opposite axis to that of our solar system?
You're second sentence is correct. What you say after that is... what can I say...
well best not to say anything
And what is wrong with "ridiculously huge" in space we have all the room and materials we need.
i won't get offended :biggrin:
i don't see what's wrong with it unless someone says something (or until i learn more) :rolleyes: yes i know that people can't build planets yet.
I think we could get by with a cable significantly shorter than 200m. We could have a mass at one end and the cabin at the other. It might also be okay if there is a force of 1.0g at ones head and 1.25g at ones feet. It couldn't be much more difficult than building a large suspension bridge.Perhaps we could use a magnetic field it the astronauts were willing to where steel gloves, steel baseball hat, and steel steel shorts(chainmail of course).
Andre said:
But keep dreaming, we first have to keep this world turning.
Tell me about it!
I guess we will never have the opportunity to really think about it.:mad:
I just don't know where to start.:rolleyes:
What does it have to do with the topic at hand?
dimensionless said:
I think we could get by with a cable significantly shorter than 200m. We could have a mass at one end and the cabin at the other. It might also be okay if there is a force of 1.0g at ones head and 1.25g at ones feet. It couldn't be much more difficult than building a large suspension bridge.).
1] You'd be okay if you only had one deck. But as soon as you have more, well, your grav is different on each deck. That's how people get injured.
2] Even at 200m you'd still experience the Coriolis force. Your "gravity" would be "warped". More injuries.
Magnetism falls off as the cube of the distance, creating a huge gradient.
maybe they have some way of making evreything in the cabin uniformly accelerate downwards. if they have tractor beams, why not have small ones lining the floor of your ship
hmm i believe that a big cylinder as a container would do, all you need is to spin it around the central axis of the cylinder, and there, the men inside feel artificial gravity to the inner layer of the cylinder...
the gravity is the same along each radius, problem is that to minimize acceleration differences you'll need the cylinder to be big enough...if my calculations are correct, if you're 1.8 meters high, and you want a gravitational acceleration difference of 2 (m/s^2) between the top of your head and you're feet, and let's say your feet accelerate in 11 , and to of the head in 9, you'll need a 9.9 meters radius, which is pretty big... though if i was to live in space, i'd love to have one of those...
another way is to put a small cabin in the edge of the craft, far from the axis of revolution, its very possible to make a ship long enough so that the acceleration difference between different positions along the small cabin are small. though this way the parts closer to the axis of revolution wouldn't have the right acceleration...(such place could be used for machines and storage)
i guess that the 2nd option is the practical one, since real space shuttles are pretty long...
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 23 ·
  • · Replies 21 ·
  • · Replies 30 ·
  • · Replies 22 ·
