Rotating cylinder, how long will it take before the angular velocity is halved
The discussion centers on calculating the time it takes for a rotating homogeneous cylinder, specifically a flywheel with a mass of 40.0 kg and a radius of 0.50 meters, to halve its angular velocity after the motor is switched off. The moment of inertia is calculated using the formula I = (m*r^2)/2, and the frictional torque is defined as M = -kw, with k being 1.2 * 10^2 Nm/s. The initial attempt at solving the equation resulted in an incorrect time value of T = -416, indicating a need for a clearer derivation of the equation of motion.
  • Understanding of rotational dynamics and angular velocity
  • Familiarity with the moment of inertia for solid cylinders
  • Knowledge of torque and friction in rotational systems
  • Ability to solve differential equations related to motion
  • Review the derivation of the equation of motion for rotating bodies
  • Study the effects of friction on angular motion in detail
  • Learn about the relationship between torque and angular acceleration
  • Explore numerical methods for solving differential equations in physics
Students studying physics, particularly those focusing on rotational dynamics, engineers working with mechanical systems, and anyone involved in analyzing the motion of rotating objects.
buksesele
A flywheel has shape as a homogeneous cylinder with mass m = 40,0 kg and radius r = 0,50 meters. The cylinder is rotating round the axis of symmetry, and is runned by a motor with constant angular velocity (w0). When the motor is switched off, the cylinder is affected by a moment of force that are caused by friction.
How long will the cylinder rotate before the angular velocity is halved?
The friction: M = -kw
w = omega
k = (1,2 * 10^2) Nm/s
The moment of inertia: I = (m*r^2)/2 (cylinder)
M = -kw => 1) w = -(M/k)
w = 1/2*w0
alpha = w/T = (1/2*w0)/T
1) (1/2*w0) = -(M/k)
(1/2*w0) = -((I*alpha)/k)
(1/2*w0) = -((((m*r^2)/2)*((1/2*w0)/T))/k)
When solving this equation the answer is: T = -416
BUT sadly we are quite sure this answer is incorrect, any help will be appreciated.
This exercice would have been more funny if only the absorbed power before switch-off had been given, and not the friction factor "k".
Anyway, you need to solve the equation of motion.
You should write the equation of motion, to make your derivation clearer,
and it could help you too.
Aha. Please see my post in your earlier thread.
  • · Replies 21 ·
