| New Reply |
Does Space Expand? |
Share Thread | Thread Tools |
| Mar26-07, 09:15 PM | #1 |
Recognitions:
Does Space Expand?
What do you think? When Cosmologist talk about the expansion of the universe, it is often phrased as space itself expanding. For instance, interpreting cosmological redshifts as due to the photons being 'stretched' as they pass through expanding space, rather than being due to a doppler shift (since for instance at cosmological distances galaxies can be receding at greater than c and hence the doppler formula breaks down).
People use analogies to dots on a balloon or raisins in bread but this seems to imply that the expansion of space (the rubber or the bread) is what carries the galaxies (the dots or raisins) apart. The idea the space expands has been attacked by various people, including the well respected John Peacock. See here, click on the link 'Expanding Space' Do people agree with this? Is Expanding Space a 'dangerous idea' or a necessary interpretation of the GR equations for FRW universes? The maths is not in dispute, but the interpretation seems to be. |
| Mar26-07, 09:20 PM | #2 |
I don't know that there's anything particularly controversial about this. In the RW metric, objects which remain at constant coordinate positions find that the physical distances (constant-time intervals) between them change over time. Since inertia will keep initially unmoving objects at constant coordinate position in a homogeneous, isotropic universe, the interpretation that space is expanding seems pretty clear.
| Mar26-07, 09:29 PM | #3 |
Recognitions:
Sure, that's a pretty clear argument you present and I agree with you. However, there are many, including Peacock, as well as Martin Reese and Steven Wienberg who wrote a New Scientist article about this some years ago who contend that thinking in this way misleads you and it's better to just think kinematically.
The classic test case is this. Imagine you are in an expanding universe and hold a galaxy at rest with respect to you but at a cosmological distance. According to Hubbles law a galaxy at that distance should be receding but you prevent this by using a chain or rockets or something to hold it in place. If you let go of the galaxy, what does it do? [THINK ABOUT THIS FIRST THEN READ ON] The answer you may assume is that since space is expanding the galaxy will start moving away from you, joining the Hubble flow eventually. However in a decelerating (but still expanding) universe the particle actually comes towards you! If you think about it it becomes clear why but Peacock argues in the link I posted that it is the idea of expanding space that leads to these misconceptions and hence should be abandoned. |
| Mar26-07, 09:34 PM | #4 |
Does Space Expand? By all means we should avoid using coordinates as if they were some physical background of general relativity. |
| Mar26-07, 09:38 PM | #5 |
Recognitions:
| Mar26-07, 10:39 PM | #6 |
I've read that distant galaxies are receding faster than light and the only way to explain this is the expansion of space. I know there is debate about the doppler shift and even the speed of light being constant. But relativity has been around a long time, and has been tested many different ways, so I will go with it until there is more consensus with regard to the newer theories.
| Mar26-07, 10:51 PM | #7 |
general (the 1915 theory) trumps special (the 1905 theory) both have been around a long time and have triumphantly passed many tests. general allows the distance between two things to increase faster than the speed of light |
| Mar26-07, 11:00 PM | #8 |
If so, then what is the definition of distance in general relativity? |
| Mar26-07, 11:20 PM | #9 |
Recognitions:
Take the proper distance, which is defined at the length of the interval between events in a frame of reference in which all events are simultaneous. In the case of an expanding universe, co-moving observers have synchronized clocks and hence taking slices through space-time of constant t is straightforward.
What we find is that the proper distance between objects can increase at a rate with respect to proper time (which is also equal to the tick rate of the co-moving observers clocks) that is greater than c. In any case, regardless of how you choose to define distance in GR, since there are different ways, there is no in-built limit on the rate of change of that distance with time, contrary to what one might expect if you had only studied special relativity. |
| Mar27-07, 12:33 AM | #10 |
OOPS, WALLACE ALREADY REPLIED! I had to be away from computer for a while and didnt see his answer. Should I edit this down or eliminate it?
Gen Rel is about distance and its relation to matter. More precisely it is about geometry and its relation to matter, but the metric or distance function is the core idea in geometry. Different geometries---different metrics---arise as solutions to the GR equation. In order to define distance one must choose a metric, the distance will be defined in that metric. One very popular and useful metric is called the FRW metric. Among several convenient and intuitive features, it has a universal time parameter---and thus a notion of simultaneity---providing for a foliation into spatial slices. Moreover in a universe governed by the FRW metric, one can say what it means for an object to be at rest. GR teaches us that we have no right to expect that the distance between two stationary points should always be the same. Commonly, solutions to the GR equation are metrics with the feature that distances either increase or decrease. Distances can change very dynamically and be increasing in one place and decreasing somewhere else. The FRW metric is simple and convenient in this regard because the increase is uniform across the board according to the time-dependent "scale factor" a(t). In a lifesize universe (excluding toy model cases) whenever you have distances increasing with that kind of uniformity, you will find superluminal recession speeds. You just have to go far enough out and the rate of increase of distance will be superluminal. I would say that General Relativity welcomes this, since it is a feature of a vast number of metrics which the theory permits, as solutions of the main equation. |
| Mar27-07, 12:51 AM | #11 |
You are right Marcus you are not obliged to explain GR basics. |
| Mar27-07, 12:56 AM | #12 |
nice example. my guess was that if the Hubble parameter was decreasing it would continue coasting towards you even after the rockets were shut off. I think that's roughly the same as what you said. =============== BTW Wallace does it help if one focuses on the idea of distances increasing rather than space expanding---to get people's minds away from the raisin-dough or stretchy-rubber idea? It could be that "space expands" is an unfortunate popularization choice of words because space is not a substance that can expand. Ontologically, all we have is the metric or an equivalence class thereof----namely the gravitational field itself---so we don't have some kind of material medium that can expand. All we have is distance and at least for now it happens to be increasing. I wonder sometimes if "Expanding Universe" wasn't a really unfortunate picture to use in getting an idea across to the general public. I think if one focuses on very gradual percentagewise increases in distance then the extension of wavelength we see in cosm. redshift can be fairly intuitive |
| Mar27-07, 01:07 AM | #13 |
You do not need to use the rolleyes smilie here! this is maybe the point you need most to understand. The distance between two stationary objects can increase indeed if they are widely enough separated so as not to be bound by physical forces, the distance normally DOES increase. read my post about the FRW metric (its idea of rest corresponds to the idea of being at rest with respect to the Hubble flow, or if you prefer the CMB, and so one can say when two objects are stationary) |
| Mar27-07, 01:20 AM | #14 |
Perhaps another patronizing posting, but this time for you, about the basics of background independence in general relativity might be fitting here. Anyway, sorry but I lost my interest in this "discussion" with you. |
| Mar27-07, 01:26 AM | #15 |
Recognitions:
But how do you explain this in a cartoon, without leading to a different misconception than the balloon types analogies lead to?? This is what I cannot work out.. |
| Mar27-07, 01:33 AM | #16 |
Recognitions:
| Mar27-07, 01:35 AM | #17 |
| New Reply |
| Thread Tools | |
Similar Threads for: Does Space Expand?
| How can "empty space" expand? (Reality behind the GR equations.) | Special & General Relativity | 38 | ||
| Wright's 'best fit' universe does not expand out into empty space | Cosmology | 3 | ||
| what physical mechanism causes space to expand? | General Physics | 5 | ||
| Expand f(x,y) = y^2/x^2 | Calculus & Beyond Homework | 5 | ||
