Solve Radio Filter Problem Using Ohm's Law & Kirchhoff's Rule
  • Context: Undergrad
  • Thread starter Thread starter BViper
    Filter Radio
The discussion focuses on designing a low-pass AM radio filter for a frequency of 130 kHz using a capacitor with a capacity of 12 nF. The solution involves applying Ohm's Law to determine the required resistance and using Kirchhoff's Rule to analyze current flow and voltage drop across the filter. The cutoff frequency is calculated based on the radio frequency, and the capacitance is derived from the resistance to ensure the filter operates effectively. These calculations assume ideal conditions, which may require adjustments in practical applications.
  • Understanding of Ohm's Law and its application in electrical circuits.
  • Familiarity with Kirchhoff's Current Law and Voltage Law.
  • Basic knowledge of filter design principles, specifically low-pass filters.
  • Experience with differential equations as they relate to circuit analysis.
  • Study the design and analysis of low-pass filters using RC circuits.
  • Learn about the implications of ideal vs. real-world circuit components.
  • Explore advanced filter design techniques, including Bode plots and frequency response.
  • Investigate the use of simulation tools like LTspice for circuit analysis and design validation.
Electronics engineers, hobbyists designing radio frequency circuits, and students studying circuit theory and filter design will benefit from this discussion.
BViper
sorry for my bad english, but this problem is translated from french. In this problem, i have to make a low-pass AM radio filter using the following information:
frequency: 130 kHz
Condensor Capacity: 12 nF
This filter must be installed in parallel with the synthesisor.
It says to use Ohm`s law and Kirchhoff`s rule to solve the problem. Before i can solve this problem, i must find a differential equation to solve. If there is not enough information, i will try to find some more but the problem only includes these values.
To solve this problem, we can use Ohm's law and Kirchhoff's rule to calculate the values needed for the filter. We can start by using Ohm's law to calculate the resistance needed for the filter. Ohm's law states that resistance (R) is equal to voltage (V) divided by current (I). In this case, the voltage is the same as the input voltage of the radio, and the current is the current passing through the filter. This current can be calculated using Kirchhoff's rule, which states that the sum of the currents entering a junction must be equal to the sum of the currents leaving the junction.
In this case, the current entering the junction is the current from the radio, and the current leaving the junction is the current passing through the filter. We can use this information to calculate the resistance needed for the filter.
Next, we can use Kirchhoff's rule to calculate the voltage drop across the filter. This voltage drop will determine the cutoff frequency of the filter. We know that the frequency of the radio is 130 kHz, so we can use this information to calculate the cutoff frequency of the filter.
Once we have the resistance and the cutoff frequency, we can use Ohm's law again to calculate the capacitance needed for the filter. This capacitance, along with the resistance, will determine the overall behavior of the filter and ensure that it acts as a low-pass filter.
In conclusion, using Ohm's law and Kirchhoff's rule, we can calculate the necessary values for the low-pass AM radio filter. It is important to note that these calculations are based on ideal conditions and may need to be adjusted in real-world scenarios.
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 28 ·
