Series and convergence/divergence help
  • Thread starter Thread starter Gauss177
    Series
The discussion revolves around understanding convergence and divergence of sequences and series, particularly focusing on specific problems related to series such as Taylor and Maclaurin series. The original poster presents several problems involving sequences and series, seeking clarification and guidance on their convergence properties.
  • Participants discuss the convergence of the sequence defined by a_n = 9^(n+1) / 10^n, with some questioning the original poster's reasoning about its divergence. Others suggest using tests like D'Alembert's test or comparison tests for the series presented.
The discussion is active, with various participants offering differing perspectives on the convergence of the first sequence and suggesting methods for the second and third series. There is an exploration of different tests that could be applied, but no consensus has been reached on the solutions.
Participants note the importance of understanding the behavior of sequences and series, with references to specific tests and comparisons that may be relevant to the problems at hand. There is also mention of potential gaps in the original poster's understanding that could be addressed through further discussion.
Gauss177
Hey all, I am really struggling to understand this chapter about series. These are a few problems about convergence and divergence, and I'll probably have some questions about Taylor and maclaurin series when I do those problems too.
1. Determine whether the sequence is convergent or divergent. If it is convergent, find its limit.
Determine whether the series is convergent or divergent:
2. 1 / n(ln n)^2, series starts at n=2 and goes to infinity
3. Find the sum of the series:
[arctan (n+1) - arctan n], series starts at n=1 and goes to infninity.
1. I broke the problem down to: 9(9/10)^n, and said that as n->infinity the sequence also goes to infinity, so it's divergent. Need my method checked on that one.
2. Don't know about this one
3. Examples I've seen of these kinds of problems end up being a geometric series, so I just use a/1-r to find out sum of the series. But I don't think this applies here, so what else should I do?
Thanks for any help :smile:
Are you sure about this. For instance, the first two terms are 9*9/10=8.1, 9*81/100=7.29. The sequence seems to be decreasing. Indeed, if you have a number 'a' such that -1<a<1, then the result of raising 'a' to any power greater than one results in a number lesser than 'a'.
I would be surprised if you were asked this question and nowhere in your textbook or class notes it was mentioned that the limit of a^n is 0 for any a such that -1<a<1.
1.the first series is pretty easy, it converges and its limit is 0.
evaluate it using dallamber's test, or criterion. DO you know what it states?
2. for the second one i did not solve it all, but i think that considering that the series 1/ln*n diverges, than i think that considering this you can find if your serie converges or diverges! So i think the comparison test will work on second one. As for the third i have no idea.
For the third one, just write out the first few terms and scratch your head.
And the second one needs an integral test.
  • · Replies 17 ·
