Something majorly wrong with this paper?
  • Context: Graduate
  • Thread starter Thread starter natski
    Paper
The discussion centers on the fundamental flaws in a mathematical model presented in a paper by the US Navy, specifically regarding the calculation of imaginary angles. The author, Natski, identifies two critical issues with the model: the calculation of Zi' leading to imaginary results and the problematic numerator in the expression for f, which also results in imaginary values. Despite the paper's frequent citations, Natski argues that the model is fundamentally flawed and seeks validation from others in the forum.
  • Understanding of mathematical modeling in physics
  • Familiarity with complex numbers and imaginary components
  • Knowledge of the specific model discussed in the paper by the US Navy
  • Experience with Mathematica for computational verification
  • Review the paper "A Mathematical Model for the US Navy" linked in the discussion
  • Learn about complex analysis and its applications in physical models
  • Explore Mathematica for advanced mathematical computations and visualizations
  • Investigate common pitfalls in mathematical modeling and how to identify them
Researchers, mathematicians, and physicists interested in mathematical modeling, as well as anyone analyzing the validity of complex models in scientific literature.
natski
As some may have noticed, I have already mentioned that this paper doesn't really seem to be very clear but now I believe its mathematical basis is fundamentally flawed. I believe this a model used by the US Navy and cited many times in recent years so I'm assuming that I must be wrong on this, however it's such a simple thing to prove that it doesn't work...
THE PAPER IN QUESTION:
http://www.jhuapl.edu/techdigest/td1703/thomas.pdf
The problem arises from the fact this model calculates imaginery angles, which is completely unphysical. There are two sources of imaginery components:
1)
Zi' formula on page 3 can be rewritten by taking out the common factor of [Cos(delta) + Z(z1',delta)]/2.
The other term is then 1+Cos[(2i-1)etc..] which can only vary from 0 to 2.
Z(z1',delta) can take a maximal value of 1 and it turns out that by using typical values that it is very close to 1 typically.
So in total Zi' varies from 0 to 2.
Now, in the expression for f, we have one term that is written as (1-(Zi'^2))^(0.5), so this obviously can be imaginery. Not only can it be imaginery, it must be for low i.
2) The second big problem lies in the numerator of f...
Zi' varies from 0 to 2. But Z(z1',delta) is a fixed value close to 1.
Consider i is high => Zi' is low and hence the bracket becomes negative.
The second bracket is the numerator cannot save the day since if Zi' is low for say delta=0, then we still have a positive number here and hence the numerator will be imaginery overall.
The first bracket in the numerator term inside the square root can also be imaginery.
The only get out clause to both of these problems would be hoping that the summation would result in the imaginery terms cancelling out, but I have observed this not to happen, unsurprisingly.
So I believe this paper's model is fundamentally flawed and I am somewhat annoyed if these are indeed genuine errors. Have I missed something or do others agree?
Natski
P.S. I have attached a mathematica notebook with my workings. They aren't really necessary to understand the problem here. I have changed some of the variables' symbols to make life easier.
Astronomy news on Phys.org
I don't see how you can remove [Cos(delta) + Z(z1',delta)]/2 from the Zi' formula given on page 3 [p 281]:
Zi'(z1',delta) = [Cos(delta) + Z(z1',delta)]/2 + [Cos(delta) - Z(z1',delta)]/2 x cos[(2i-1)pi/400]
Ah you don't know how grateful I am for someone spotting that. My paper copy has that sign faded and I thought it was a +. I have retried the formula and am now getting real values again so many thanks Chronos.
Natski
  • · Replies 0 ·
  • · Replies 58 ·
  • · Replies 19 ·
