Why is a higher resolution necessary for larger molecules in mass spectrometry?
The discussion centers on the necessity of higher resolution in mass spectrometry for analyzing larger molecules compared to smaller ones. Participants explore the implications of molecular weight (M.W.) on resolution requirements, particularly in the context of distinguishing between closely related mass peaks.
  • One participant notes that the resolution required is defined as M/(delta M), suggesting that larger molecules necessitate greater resolution even if delta M remains constant.
  • Another participant proposes that small molecules have unique empirical formulas for specific M.W., making them easier to identify with lower resolution, while larger biological molecules present more combinations that complicate identification.
  • A different participant illustrates that the required resolution to distinguish two mass peaks increases with the mass of the molecules, using specific examples of atomic masses to highlight this point.
  • One participant emphasizes the impact of data quality, mentioning that real-life data contains errors and deviations, which necessitate higher resolution to accurately distinguish between peaks.
Participants express varying levels of understanding and agreement regarding the reasons for increased resolution requirements for larger molecules, indicating that multiple competing views remain on the topic.
Participants acknowledge the influence of data quality and the presence of errors in real-world measurements, which may complicate the resolution requirements further. There is also an implicit assumption that the definitions of mass resolution and the implications of molecular weight are understood but not universally agreed upon.
This discussion may be useful for individuals interested in mass spectrometry, particularly those exploring the challenges associated with analyzing larger biological molecules and the technical aspects of resolution in mass spectrometry.
schordinger
In mass spectrometer, the resolution required was defined as
M/(delta M), So, it means for two larger M.W. molecules, the resolution required was larger than small M.W. molecules even the delta M was was the same...
But why ??!
why the instrument should have better resolution to distinguish different larger molecules ??!
Thx...[?]
Biology news on Phys.org
Don't know much about mass spectroscopy.
But if I had to guess...
For small molecules, the empirical formula can be calculated from the MW. There's only one formula possible for the MW 130.1418, for example. Even mass spectrometers with low resolution can figure it out for small molecules. WIth large, particularly biological molecules there are more combinations and permutations that can give very similar MW's. So having a high resolution probably helps here. But I'm not sure. I don't handle many compounds more then several hundred daltons.
Chemicalsuperfreak, thanks for your reply
I agree with your point.
However, I still don't understand in some sense.
For example, if 2 molecules, the first has atomic mass 22.01 and the second one has 22.00, the mass resolution required to distinguish THE TWO molecule was 22/0.01. Another 2 molecule have atomic mass 122.01 and 122.00, the resolution required for distinguish this TWO VALUE (PEAK) was 122/0.01.
As the delta M was 0.01, in common sense, what the instrument required was it can distinguish 0.01 mass difference. The mass of the peak were not related, if just consider two peak. In fact, mass resolution was defined as "the maximum resolution required to distinguish of two peak"
:smile: [?]
Remember, in real life, you have crud in your data. You have error, you have deviations. It will require a higher level of resolution to distinguish between two peaks as their standard deviations may increase.
Now you may feel pity for all those people doing mass spec of polymers and proteins.
  • · Replies 23 ·
