How Do You Find a Power Series Representation for f(x) = x / (4+x)?
The problem involves finding a power series representation for the function f(x) = x / (4+x) and determining its interval of convergence. Participants express uncertainty about how to start the problem and explore various methods for deriving the series.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Some participants suggest using a geometric series approach, questioning the values of 'a' and 'r' needed for convergence. Others mention the possibility of using Taylor series expansion and express concerns about the potential for error in calculations. There are discussions about rewriting the function and using long division as an alternative method.
The discussion is active with multiple approaches being explored. Some participants provide guidance on using geometric series, while others caution about the complexity of Taylor series calculations. There is no explicit consensus on the best method, but several productive lines of reasoning are being examined.
Participants note the potential for errors in calculations, particularly with Taylor series, and emphasize the need to clarify assumptions about convergence in the context of geometric series.
kskiraly
Find a power series representation for the function
f(x) = x / (4+x)
and determine the interval of convergence.
I have no idea how to begin this problem.
My only guess would be trying to divide something out in order to simplify to something that I'm able to create something of the form (x+c)^n
I can work out to the interval of convergence, I am just unsure of how to create the representation.
Try this one:
It is a geometric series, so I am not so sure that it is the correct answer to your question.
Taylor series expansion about x=0. Substitute expression for the nth derivative of f(x) evaluated at x=0.
The answer comes to
f(x)=-sum (-x/4)^n
where the sum is from 0 to infinity
Malawi glenn was steering you right! The geometric sequence [itex]\sum_{n=0}^\infty ar^n[/itex] converges to [itex]\frac{a}{1- r}[/itex]. Now what must a and r be in order to converge to
[tex]\frac{x}{4+ x}= \frac{\frac{x}{4}}{1-(-\frac{x}{4})}}[/itex]? For what values of r does a geometric series converge?<br /> <br /> Yes, you could do this by differentiating and forming the Taylor's series but that is tedious with lots of room for error. And, in fact, the answer given by christianjb is incorrect: For x= 0, "f(x)=-sum (-x/4)^n,where the sum is from 0 to infinity" is 1 while x/(1+ x) is 0.[/tex]
Rewrite as [itex]x\cdot \frac{1}{x+4}[/itex] and use long division.
[tex] <br /> I should have said n=1,infiniy. Then the answer is correct.[/tex]
Yes. Minor detail but that's the point- calculating the Taylor's series leaves a lot of room for error!
I agree that the geometric series method is more elegant in this case.
  • · Replies 22 ·
