Sinusoidal Wave: Double Frequency, Double Speed
  • Thread starter Thread starter Andy_ToK
    Sinusoidal Wave
The discussion centers on the relationship between frequency and wave speed in a sinusoidal wave traveling along a string of uniform density. The correct conclusion is that doubling the frequency does not double the speed of the wave; instead, the speed remains constant. This is due to the fact that wave speed is determined by the tension and density of the string, as expressed in the equation v = λ * f, where λ is the wavelength and f is the frequency.
  • Understanding of wave mechanics
  • Familiarity with the equation v = λ * f
  • Knowledge of tension and density effects on wave speed
  • Basic concepts of sinusoidal waves
  • Study the effects of tension on wave speed in strings
  • Explore the relationship between wavelength and frequency in wave phenomena
  • Learn about different types of waves and their properties
  • Investigate the impact of density on wave propagation
Physics students, educators, and anyone interested in wave mechanics and the properties of sinusoidal waves.
Andy_ToK
A sinusodial wave is moving along a string of uniform density. If you double the frequency of the wave,
a)the speed of the wave doubles
b)the speed of the wave remains about the same
v=lambda*f
I chose a) using the equation v=lambda*f. as f doubles, v doubles too.
That would only be true if the wavelength remained the same.
What determines the speed of a wave on a string?
tension and density.
The answer is b)
