Rotational and Translational Motion
The discussion revolves around a physics problem involving rotational and translational motion, specifically concerning a bucket of water suspended by a rope around a windlass. The scenario includes calculations related to tension in the rope, time of fall, speed upon impact, and forces on the windlass during the fall.
  • Mixed
  • Participants discuss the application of torque and rotational dynamics to find the tension in the rope and other related quantities. There are attempts to derive relationships between tension, angular acceleration, and linear acceleration. Some participants express confusion about specific equations and their derivations.
There appears to be some initial uncertainty regarding the correctness of the calculated tension, but later posts indicate that some participants have verified the calculations and found them to be correct. Questions about the reasoning behind certain equations are also raised, suggesting ongoing exploration of the concepts involved.
Participants are working under the assumption that the rope remains wrapped around the cylinder throughout the process, and there is a focus on understanding the relationships between the various forces and motions involved in the problem.
doopokko
A bucket of water of mass 14.2 kg is suspended by a rope wrapped around a windlass, that is a solid cylinder with diameter 0.350 m with mass 12.1 kg. The cylinder pivots on a frictionless axle through its center. The bucket is released from rest at the top of a well and falls a distance 11.0 m to the water. You can ignore the weight of the rope.
Solve for:
1) tension in the rope
2) time before the bucket hits the water
3) speed at which the bucket hits the water
4) force exerted on the cylinder by the axle during the fall
Torque=R*F*sin(phi)
Torque=I*alpha
I=(M*R^2)/2
M=12.1 kg (mass of cylinder)
R=0.175 (radius of cylinder)
m=14.2 (mass of bucket)
Torque = 0.175 * Tension = 1/2 * 12.1 * 0.175^2 * alpha
Torque = 0.175 * Tension = 0.18528125 * alpha
1.05875 * alpha = Tension
Weight = 14.2 * 9.8 = 139.16
ForceNet (on bucket) = Weight - Tension = m*a
ForceNet = 139.16 - Tension = 14.2 * a
139.6 - 1.05875*alpha = 14.2 * a
Tension = (1/2) * M * a
Tension = 41.57619
But I've been told that this isn't the correct answer. Can somebody set me straight, please?
There shouldn't be problems, as long as the rope is assumed to be wrapped on the rim of the cylinder throughout the whole process.
Solve for:
Torque=R*F*sin(phi)
Torque=I*alpha
I=(M*R^2)/2
Tension = 41.57619
It looks pretty good to me. I think you've got it right.
edit: Worked it out, got the same answer. Can't see why it would be wrong...:confused:
Hahaha, I went through again and it turns out that that really was the right answer after all. I think there are just some wires crossed in my brain.
Thanks to everyone who looked this over, though.
Hey guys, why is the tension 1/2 * M * a ? Am a bit confused about that..
That fact can be deduced by combining these formulas (plus one other):
doopokko said:
Torque=R*F*sin(phi)
Torque=I*alpha
I=(M*R^2)/2
  • · Replies 21 ·
  • · Replies 29 ·
  • · Replies 97 ·
  • · Replies 63 ·
