How can we improve the accuracy of acceleration calculations?
  • Context: Undergrad
  • Thread starter Thread starter salamander
    Acceleration
The discussion focuses on improving the accuracy of acceleration calculations using Newtonian physics. A user seeks guidance on deriving the velocity of a falling rock as a function of time, incorporating gravitational attraction that varies with distance from Earth. The key equation presented is the non-linear differential equation m(d²r/dt²) = -GMm/r², which leads to the integration of velocity and distance. The final expression for velocity is v = √(2GM/r + C), demonstrating the relationship between kinetic and potential energy.
  • Understanding of Newtonian mechanics and gravitational theory
  • Familiarity with differential equations and integration techniques
  • Knowledge of conservation of energy principles in physics
  • Basic calculus, particularly the chain rule and integration methods
  • Study the derivation of gravitational force using Newton's law of universal gravitation
  • Learn about non-linear differential equations and their solutions
  • Explore the conservation of energy in mechanical systems
  • Investigate numerical methods for solving differential equations in physics
Students of physics, educators teaching mechanics, and anyone interested in advanced calculations of motion under gravitational forces.
salamander
Hi! I'm quite new here, and I'm not sure wheter this is to go here or in the math section, so I'll just post it here since i guess nobody really care anyway.
I've been thinking of this for a while, but I can't seem to get it right. (I'm not that good at maths but I'm learning.)
Concider dropping a rock from a rather high altitude down to the ground. Now, using Newtonian theory, find an expression for the rocks' velocity as a function of time, that includes the fact that the gravitational attraction must become greater as the distance to Earth shrinks.
Can somebody give me a hint?
I know g=MG/r^2
What confuses me is how to integrate time in this expression,
since r=r0-gt^2/2
Finally, I don't know why but i just like these guys:
You need to set up a differential equation relating the distance from the Earth to the acceleration and solve it.
Letting r be the distance from the center of the earth,
[tex]m\frac{d^2r}{dt^2}= \frac{-GmM}{r^2}[/tex]
That's a non-linear differential equation but we can use the fact that t does not appear explicitely in it: Let v= dr/dt. Then (chain rule):
[tex]\frac{d^2r}{dt^2}= \frac{dv}{dt}= \frac{dr}{dt}\frac{dv}{dr}= v\frac{dv}{dr}[/tex]
so the differential equation becomes
[tex]v\frac{dv}{dr}= \frac{-GM}{r^2}[/tex] and then separate:
[tex]v dv= -GM \frac{dr}{r^2}[/tex]. Integrating:
[tex]\frac{1}{2}v^2= \frac{GM}{r}+ C[/tex].
(Notice that that first integral is the same as
[tex]\frac{1}{2}v^2- GM/r= C[/tex], conservation of energy, since the first term is kinetic energy and the second potential energy.)
That is the same as [tex]v= \frac{dr}{dt}= \sqrt{2\frac{GM}{r}+ C}[/tex] which is also integrable. You can use the fact that GM/r02= g (r0 is the radius of the earth) to simplify.
  • · Replies 41 ·
22K
  • · Replies 22 ·
