Is C Closed, Open, or Neither? Understanding the Topology of R^2 and the Set C
  • Thread starter Thread starter pivoxa15
    Closed
The discussion revolves around the topology of the set C in R^2, specifically whether C, defined as C={(x,y)|x in Q, y in R}, is closed, open, or neither.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants explore the nature of C as an infinite union of closed sets and question the implications of this on whether C is closed. They discuss the properties of closed sets and limits of sequences, particularly focusing on rational and irrational numbers.
The discussion includes various perspectives on the properties of C, with some participants providing insights into the nature of limits and closures in topology. There is an ongoing exploration of the definitions and implications of closed and open sets without reaching a consensus.
Participants are considering the definitions of closed sets in the context of metric topology and the behavior of rational and irrational numbers within R.
pivoxa15
Consider R^2 and the set C={(x,y)|x in Q, y in R}
Is C closed, open or neither?
C consists an infinite union of closed sets (infact straight lines in the plane). Is an infinite union of closed sets not closed? If so why. C is clearly not open.
An infinite union of closed sets is not necessarily closed for the same reason an infinite intersection of open sets is not necessarily open.
If the set is closed, sequences in the set with a limit have a limit in the set. Is this true?
Good point.
Any infinite continued fraction equals an irrational number
Consider an infinite sequence of finite continued fractions that converge in the limit to an irrational number. The fact that each element in the sequence is a finite fraction means it is a rational number hence on the x-axis but the limit of this sequence is an irractional number which is not in C so C is not closed.
C is not open because one can draw a ball around any point in C and not every point in the ball is in C.
Yea, although it's slightly easier to just note that any real number is the limit of a sequence of rationals (say, the truncated decimal expansions). Also, you need to show that there is no ball around the point contained in C, not just that some ball isn't.
So I should have said for any ball with radius r>0, there will be points in the ball not in C.
If a set is closed it is its own closure. WHat is the closure (in the metric topology) of the rationals in the reals? By *definition* it is all of the reals, so the rationals are not closed. (we'll assume you can assume that there are non-rational real numbers).
  • · Replies 17 ·
  • · Replies 38 ·
10K
