The Klein bottle using the Euler caracteristic + orientability caracterisation
  • Context: Graduate
  • Thread starter Thread starter quasar987
    Euler Klein
The discussion centers on the Euler characteristic and orientability characterization of the Klein bottle, specifically addressing the confusion surrounding its homeomorphism to \mathbb{R}P^2\#\mathbb{R}P^2. The Euler characteristic formula for two surfaces, \chi(M\#N)=\chi(M)+\chi(N)-2, is applied, leading to the conclusion that the Klein bottle has an Euler characteristic of zero, similar to a torus. The participant initially misinterprets the #_k notation, which refers to the number of spaces glued together, ultimately clarifying that k should be 2, not 1.
  • Understanding of Euler characteristic in topology
  • Familiarity with orientability of surfaces
  • Knowledge of homeomorphism concepts
  • Basic skills in triangulation of surfaces
  • Study the properties of non-orientable surfaces in topology
  • Learn about triangulation techniques for complex surfaces
  • Explore the implications of the Euler characteristic in algebraic topology
  • Investigate the classification theorems of surfaces and their applications
Mathematicians, topology students, and educators interested in advanced concepts of surface classification and Euler characteristics.
quasar987
I went off on my own to study the Euler caracteristic + orentability caracterisation of closed surface and I must have gotten lost somewhere, because I do not find that the Klein bottle is homeomorphic to [itex]\mathbb{R}P^2\#\mathbb{R}P^2[/itex] as I should.
I started with the result that for two surfaces M and N, we have
[tex]\chi(M\#N)=\chi(M)+\chi(N)-2[/tex]
then I proved by induction that
[tex]\chi(M^{\#_k})=(k+1)\chi(M)-2k[/tex]
which can be solved for k:
[tex]k=\frac{\chi(M^{\#_k})-\chi(M)}{\chi(M)-2}[/tex]
Now, the Klein bottle is not orientable, so it must be homeomorphic to [itex](\mathbb{R}P^2)^{\#_k}[/itex] for some k. And since the Euler caracteristic is a topological invariant, it must be that
[tex]\chi((\mathbb{R}P^2)^{\#_k})=\chi(K)[/tex]
And so, according to the above formula for k, with [itex]\chi(M)=\chi(\mathbb{R}P^2)=1[/itex],
[tex]k=\frac{\chi(K)-1}{1-2}=1-\chi(K)[/tex]
So all that remains to do is to triangulate K and find its Euler caracteristic. A fundamental polygon for the Klein bottle is provided here:
http://en.wikipedia.org/wiki/Classification_theorems_of_surfaces#Construction_from_polygons
I believe it can be triangulated simply by drawing a side across one of the diagonal. All the vertices are identified, so V=1. There are 3 distinct sides, so E=3. My triangulation has 2 triangles so F=2, thus
[tex]\chi(K)=1-3+2=0[/tex]
But this means that k=1, which is incorrect. It should be 2.
Where did I go wrong?
well your euler characteristic calculation seems correct, since just looking at a picture of a klein bottle (the picture in my head) shows it obviously has the same edges faces and vertices as a torus, hence has the same euler chracteristic, namely zero. so the error is likely somewhere else.
Whoah! There's no error at all !
[tex]\mathbb{R}P^2\#\mathbb{R}P^2 = (\mathbb{R}P^2)^{\#_1}[/tex]
k=1 is correct!
Edit: No! k should be 2 but I made an error in the very beginning by misinterpreting the #_k notation. I thought k referred to the number of # symbol, while it refers to the number of spaces you glue together.
  • · Replies 0 ·
  • · Replies 26 ·
  • · Replies 21 ·
  • · Replies 25 ·
