| Thread Closed |
2 questions about the double slit experiments |
Share Thread | Thread Tools |
| Apr6-07, 10:37 PM | #1 |
I Have two questions in my mind about the double slit experiment about the electrons, i would be glad if you guys could clear it up.
1)When we try to observe which slit the electron is going through, how exactly do we go about making the measurement? what kind of "device" or "technique" do we use? and 2) If suppose we were to observe only 1 slit instead of the two, then what would happen? Cause if we observe only one slit then we will know which slit exactly the electron is going through, (cause if we don't detect it in the slit we observe, then its naturally going in through the other one) Then since we do not directly "observe" the second slit, what happens then? do we get an intereferance pattern? or what exactly do we get? Thx... |
| Apr7-07, 10:43 AM | #2 |
The easiest way to learn which slit the electron is going through is to block off one completely. This is often done in an alternating manner of some kind in order to build up a suitable pattern to demonstrate the result.
Experiements have also been done - as confirmation - in which a beam of photons is used to determine which slit the electron goes through. In this scenario, the light beam is directed across the direction of travel of the electron. |
| Apr7-07, 01:13 PM | #3 |
1st - As DrC said - you use a beam of light in front of just one slit to detect the shadow of any electron going through that slit. 2nd - Now just as you proposed - they can count only those individual electrons that hit the screen when no shadow of an electron is detected. After all we can not expect an electron that has been hit by enough photons to stay on its same original path. 3rd - This way we can view just the pattern caused by only those electrons, that we now for sure "which way" they went, AND we also know we did not touch or disturb them. So now what have they observed when they carefully look at the pattern of only these undisturbed electrons going though just one of two slits? Of all the many times, (many, many, many times – there do this a lot because it is confusing) this experiment is done they always get the same result – a single slit pattern i.e. With No Interference! Confusing? Well yah, that’s why it takes a ‘confusing’ Non-local theory to explain or understand it. Lots of choices there – OQM, MWI, BM-guide waves, String Multi Dimensions, superposition/entanglement, etc |
| Apr7-07, 01:39 PM | #4 |
So, do I have it right? If only one slit is used you get a single dot opposite the slit, no intereferance. If you use both slits, one at a time, you get the same intereferance pattern as if electrons were going through both slits at the same time. Right? -Robert
| Apr7-07, 02:24 PM | #5 |
A single slit gives you a wide random patten, not a single dot. you must send many electrons to collect data. one electron by itself cannot create any kind of pattern. And as I said the double slit pattern for just the electrons you have figure out which way thay have gone looks the same as this single slit random pattern - no interferance bars. Thats what makes the paradox. |
| Apr7-07, 04:47 PM | #6 |
Recognitions:
| Apr8-07, 07:14 AM | #7 |
Yes, sorry I wasn't clear. If you block only one of two slits at a time alternately while sending many electrons, one at a time through the open slit, you would get an intereferance pattern just as though both slits were open at the same time. By the way the experiment has been done with atoms also with the same result. I read this in a book called "Schrodinger's Kittens and the Search for Reality" by John Gribbin, very good reading. -Robert
| Apr8-07, 07:37 AM | #8 |
Mentor
| Apr8-07, 10:07 PM | #9 |
Actually I disagree with the comments about having a scatter pattern when you only have 1 slit versus two. I posted another thread on this a few minutes ago before I noticed this one. I'm not one to take other peoples word for things so I've actually built my own experiment to test this subject. In 100% of my tests, I get an interference pattern not only with one slit, but even if I have no slits and just block half the pathway with something solid.
I don't see strangeness in my experiments and I believe I can actually explain what is happening but would love to hear some opinions before I offer mine. The fact is, I take a laser beam, or a hand held flash light from walmart and shine it past a book sitting on the table, I get a perfect set of lines on the back wall. No slits at all. By the way, can anyone explain the bending of light? Because I think I can using the results of my experiments and was wondering if we already knew in detail why it bends. Thanks, glenn |
| Apr8-07, 10:39 PM | #10 |
Recognitions:
Also, to see a visible interference pattern, the distance between slits has to be pretty small, you might need to use a diffraction grating--this page says that the relationship between the light's wavelength [tex]\lambda[/tex] and the distance between interference bands [tex]\Delta x[/tex] is [tex]\lambda = \Delta x (d/L)[/tex], where d is the separation between the slits and L is the distance between the slits and the screen. So if you use a red laser with a wavelength of around 680 nanometers, and L is 1 meter, then in order to have the bands be 1 millimeter apart, the distance between slits would have to be 0.68 millimeters (and if you want the bands to be twice as far apart, you have to either divide the distance between slits by 2, or multiply L by 2). |
| Apr9-07, 04:12 AM | #11 |
Hey.. thx for replying to the thread guys... appreciate it... well... you cleared up my doubts... but i guess its gonna be awhile before someone clears up the the whole thing though...
| Apr9-07, 08:51 AM | #12 |
The experiment from John Gribbin's book, page 5, goes like this. There are TWO slits open at all times. Photons are put through the experiment one at a time. After millions of photons have passed through and accumulated on a photo plate an intereferance pattern forms. This was actually done in the mid 80's. In the 90,s it was done with atoms. Thanks for the correction. I hope I got it right this time. -Robert
| Apr9-07, 09:01 AM | #14 |
Mentor
Diffraction by Opaque Barrier |
| Apr9-07, 02:03 PM | #15 |
1) It states that the distance between the slit and the back surface needs to be substantial, but I can duplicate my results with only a 2 foot seperation. I can also duplicate simply by breaking the light in half, not with a slit. Is 2 feet a large enough distance to see what they are talking about? Should a slit actually be required to see the banded pattern? Thanks, glenn |
| Apr9-07, 02:22 PM | #16 |
Mentor
| Apr9-07, 04:00 PM | #17 |
Recognitions:
| Thread Closed |
| Thread Tools | |
Similar Threads for: 2 questions about the double slit experiments
| Questions about Young's Double-Slit experiment and light waves intereference | Introductory Physics Homework | 8 | ||
| Wave/Particle Double Slit Experiment Questions | Quantum Physics | 10 | ||
| Problem: Plastic Covering One Slit in Double Slit Experiment | Introductory Physics Homework | 5 | ||
| Double-Slit Questions | Quantum Physics | 35 | ||
| double-slit questions | Quantum Physics | 9 | ||
