Why Do I See Patterns and Lights When I Press My Eyes?
  • Thread starter Thread starter revesz
    Energy Mind
The phenomenon of seeing patterns and lights when applying pressure to the eyes is primarily attributed to *photopsia*, which occurs due to stimulation of retinal receptor cells by the vitreous gel. This stimulation can lead to luminous visual experiences, as described by users in the forum. Additionally, spontaneous neuronal firing in the visual cortex contributes to these visual effects, suggesting a complex interaction between the eye and brain. The retina functions as an extension of the brain, reinforcing the connection between visual perception and neurological activity.
  • Understanding of *photopsia* and its causes
  • Basic knowledge of retinal anatomy and function
  • Familiarity with neuronal firing and visual processing
  • Awareness of the relationship between the retina and the brain
  • Research the mechanisms of *photopsia* and its implications
  • Explore the anatomy of the retina and its connection to the brain
  • Investigate the effects of pressure on the eye and its visual consequences
  • Learn about the impact of drugs and meditation on visual perception
Individuals interested in neuroscience, ophthalmology, and visual perception, including students, researchers, and healthcare professionals seeking to understand the interplay between visual stimuli and brain activity.
revesz
im wondering what these images i see are. When i close my eyes and gently push the palmes of my hand into my eyes, after about 30 seconds, i start seeing swirling lights and strings and squares, and detailed contantly shifting shapes that i can't possibly describe accuratly.
It is fascenating, it's like something you would see in an out of body experience, try it and see for yourself. its easy to do, i just push the bottom of my palm into my eye socket and i start to see matrix like effects, first everything goes yellow, then there are random flashing boxes of uncertain colour, then a matrix of digitalized geometry, laced with energy waves and worms that move and react to one another.
try it then tell me if you see anything like what i have described.
What is all this stuff, and why don't i always see it? i think it is a result of blood displacement within the visual part of the brain, just behind the eye, or mabye its just me giving myself brain-damage(hope not). so tell me what this is, or what causes it, is it something the brain creates, or is it received from the eye?
Biology news on Phys.org
Originally posted by revesz
...so tell me what this is, or what causes it, is it something the brain creates, or is it received from the eye?
Hi revesz,
I think that there's a combination of two things possibly happening.
I think in part, the phenomenon you're describing is a form of *photopsia* caused by stimulation of retinal receptor cells by pressure from the vitreous gel. If you close your eye and push your eyeball firmly from the outer corner, you can elicit a luminous photopsia more lucidly... that's a direct stimulation of the retinal receptor cells. (Just don't push too firmly...)
But the second thing happening is that the both the receptor cells and the cells of the visual cortex can experience random noise (i.e. neuronal firing) that occurs spontaneously in the absence of visual stimuli.
So it might be from both the brain and the eye... but having said that, the retina is actually a part of the brain -- the receptors (rods and cones) are histologically neuronal cells, and so you could think of them as an extension of the visual cortex, connected to the brain by long afferent axons (i.e. the optic nerve).
Regards,
metasystem
it doesn't look like random noise, it looks more like a fractal image, that a computer might have created. i have never heard reference to this anywhere before, but i find it usefull in understanding how the brain works, its as if i can see an ever changing display of light, its beautiful, i think the effect would be mostly from signals sent into the visual cortex, by the receptors, mabye it works the way nerves work, and the pressure creates a response, exept that the brain interprets this signal differently. so i would expect the same effect to be experienced if someone were haveing brain surgery or having some trauma to the brain, this may also be inducable with drugs, or meditation.
  • · Replies 41 ·
11K
  • · Replies 17 ·
9K
