How fast is the center of mass of a tissue paper roll when its radius is 0.14cm?
  • Thread starter Thread starter Houyhnhnm
    Paper Roll
The discussion revolves around determining the speed of the center of mass of a cylindrical roll of tissue paper as it unrolls, specifically when its radius has decreased to 0.14 cm from an initial radius of 6.1 cm. The problem involves concepts from mechanics, including angular momentum and energy conservation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the use of conservation of energy and question the relevance of initial conditions, such as initial velocity. There is discussion about the potential need for additional information to solve the problem effectively.
The conversation includes various attempts to clarify the problem, with some participants suggesting the need for more information regarding initial conditions. Others provide insights into the equations related to rotational kinetic energy and moment of inertia, while also noting ambiguities in the problem setup.
Participants express uncertainty about the initial velocity after the roll is pushed and whether the problem requires considering the paper that is left behind. There is also mention of gravitational acceleration as a given parameter, raising questions about its necessity in the calculations.
Houyhnhnm
OK here's a question which I really, really can't understand.
A large, cylindrical roll of tissue paper of initial radius R lies on a long, horizontal surface with the outside end of the paper nailed to the surface. The roll is given a slight shove (initial velocity is about zero) and commences to unroll. Determine the speed of the center of mass when its radius has diminished to r = .14cm assuming R is 6.1cm.
Somebody told me to use angular momentum, but how can I when the initial velocity is zero? I'm quite confused. Also, they give that g = 9.80 m/s^2, why would we need that?
Do you know about conservation of energy?
Is there such thing as rotational potential energy?
More info is needed. You can't solve this without at least knowing the initial velocity (after it's pushed).
[tex]\lim_{\vec{v}_0 \rightarrow \vec{0}}\vec{v}[/tex] exists, so you can just assume that the inital velocity is arbitrarily small.
No, there is however, rotational kinetic energy --
[tex]KE_{rot}=\frac{1}{2}I\omega^2[/tex]
The moment of inertia of the cylinder is [tex]\frac{1}{2}MR^2[/tex]
One of the problems is that the problem is unclear about which center of mass it wants to know about (whether to include the dropped paper or not).
Leaving the paper behind makes things significantly more complicated, so I'll use the other answer.
This leads to the following equation:
[tex]mhg=\frac{1}{2}I\omega^2+\frac{1}{2}mv^2[/tex]
which has two unknowns, so we need a second equation which relates the velocity of the center of gravity to the angular speed.
If we assume that the toilet paper has negligible thickness, then we get:
[tex]\omega=\frac{v}{r}[/tex]
Applying the formula for moment of inertia yieds
[tex]I=\frac{1}{2}mr^2=\frac{1}{2}M\frac{r^3}{R^2}[/tex]
The change in height of the center of gravity:
[tex]h=R-\frac{r^3}{R^2}[/tex]
If we plug things back in we get:
[tex]Mg(R-\frac{r^3}{R^2})=v^2(\frac{r^2}{4R^2}M+\frac{1}{2}M)[/tex]
the [tex]M[/tex]'s cancel
[tex]g(\frac{R^3-r^3}{R^2})=v^2(\frac{r^2+2R^2}{4R^2})[/tex]
The denominators cancel
[tex]\sqrt{\frac{g(R^3-r^3)}{r^2+2R^2}}=v[/tex]
This is the velocity of the center of gravity. The velocity of the center of the cylinder is
[tex]\frac{R^2}{r^2}\sqrt{\frac{g(R^3-r^3)}{r^2+2R^2}}[/tex]
I come up with roughly [tex]40 m/s[/tex] for the small cylinder, and roughly [tex]2 m/s[/tex] for the center of gravity of the whole roll. YMMV, and you should check to make sure what I did makes sense, and whether you can catch the math errors I snuck in.
