Proving Simple Pole of $\frac{1}{1-2^{1-z}}$ at $z=1$
  • Context: Graduate
  • Thread starter Thread starter Diophantus
    Pole
The discussion revolves around proving that the function \(\frac{1}{1-2^{1-z}}\) has a simple pole at \(z=1\). Participants explore various methods including Taylor series, Laurent series, and limits, while addressing the nature of poles in complex analysis.
  • One participant suggests proving the pole by showing that \(\lim_{z\to 0} \frac{z}{1-2^{1-z}} = 1\), but later expresses uncertainty about this approach.
  • Another participant proposes using the Laurent series to demonstrate the presence of a pole, but questions the validity of the geometric series expansion near \(z=1\).
  • A different approach involves calculating the residue using l'Hospital's rule, leading to different proposed values for the residue at the pole.
  • Some participants discuss the implications of the complex logarithm and the primary branch, raising questions about the nature of solutions to \(2^{1-z} = 1\).
  • There is a contention regarding the definition of a simple pole and the conditions under which \(2^{1-z}\) equals 1, with references to the derivative not being zero.
  • Participants express confusion over the relevance of certain methods and definitions, particularly regarding the primary branch of the complex logarithm and its implications for the discussion.
Participants do not reach a consensus on the methods for proving the existence of a simple pole, with multiple competing views and approaches presented throughout the discussion.
Some participants express uncertainty about the mathematical steps involved, particularly in relation to the series expansions and the implications of the complex logarithm. The discussion reflects a range of interpretations regarding the definitions and properties of poles in complex analysis.
Diophantus
How exactly would one go about proving that
[tex]\frac{1}{1-2^{1-z}}[/tex] has a simple pole at [tex]z=1[/tex]?
I've tried writing [tex]2^{1-z}[/tex] in terms of e to get a Taylor series for the denominator but can't quite figure out where to go from there.
In complex analysis, a pole of a holomorphic function is a certain type of simple singularity that behaves like the singularity 1/z^n at z = 0. A pole of order 1 is called a simple pole as you know. Essentially you need to prove
z behaves like 1-2^(1-z) near zero. Perhaps if you showed that [tex]\lim_{z\to 0} \frac{z}{1-2^{1-z}} = 1[/tex]...
Scratch that, I am not sure that helps..All you should need to show is that it approaches the same limit, so the first one, z, as z goes to 0, its just zero. the second one is also 0. That should do it.
If your not happy, show that the function Laurent series near z=1 below degree −n vanishes and the term in degree −n is not zero.
OK so I've opted for the Laurant Series route. Where am I going wrong here:
[tex]\frac{1}{1-2^{1-z}} = \displaystyle\sum_{n=0}^{\infty}(2^{1-z})^n = \displaystyle\sum_{n=0}^{\infty}(e^{(1-z)log2})^n = \displaystyle\sum_{n=0}^{\infty}(\displaystyle\sum_{m=0}^{\infty}\frac{(1-z)^m(log2)^m}{m!})^n[/tex]
This doesn't look like it has any singilarities.
I'm not sure using the geometric series is really valid for about z = 1, I can get an appropriate series on mathematica which shows it is a simple pole, but I have no idea how to generate it myself.
If it has a simple pole, then the residue should be bounded and given by
[tex]R=\lim_{z\rightarrow 1} (z-1)f(z)=\lim_{z\rightarrow 1} \frac{z-1}{1-2^{1-z}}.[/tex]
Substitute [tex]u=z-1[/tex] to get
[tex]R=\lim_{u\rightarrow 0} \frac{u}{1-2^{-u}}[/tex]
Evaluating using l'Hospital's rule gives R=2.
EDIT: Accordingly, 2/(z-1) is a term in the Laurent series.
EDIT2: define u=z-1 instead of 1-z for clarity
Hmmm, it's actually 1/log2 but thanks anyway. I'm really intrigued to know whether there is a reasonable way of calculating the Laurant series though. Surely there must be a bit of trickery that will work.
Oops! I took the derivative wrong! Very sorry :blushing:
you want to show [z-1] over that function is bounded.
but you just want to show 2^(1-z) equals 1 simply when z=1, or that 2^z equals 1 simply when z=0, but that's sort of clear, since the derivative is not zero anywhere, 2^z has no multiple values at all.
I'll repeat my earlier derivation, without the silly error.
[tex]f(z)=\frac{1}{1-2^{1-z}}=\frac{2^z}{2^z-2}[/tex]
has a pole if the residue
[tex]R=\lim_{z\rightarrow 1} (z-1)f(z)=\lim_{z\rightarrow 1} \frac{2^z (z-1)}{2^z-2}[/tex].
is bounded. To evaluate via l'Hospital's rule, write
[tex]2^z=(e^{\ln2})^z=e^{z\ln2}[/tex]
so the derivative is
[tex]\frac{d(2^z)}{dz}=2^z \ln(2).[/tex]
Then
[tex]R=\lim_{z\rightarrow 1} \frac{2^z[1+(z-1)\ln(2)]}{2^z \ln2} = \frac{1}{\ln(2)} .[/tex]
Hope I redeemed myself! o:)EDIT: It's even simpler to define u=z-1, then
and applying l'Hospital's rule gives
[tex]R=\lim_{u\rightarrow 0} \frac{1}{2^u \ln(2)}=\frac{1}{\ln(2)}.[/tex]
didnt i make this trivial? or did i screw up?
Can't answer 'cause I don't know what you mean by "2^(1-z) equals 1 simply when z=1"?
>.<" Perhaps the "simply" is troubling you? Thats not a mathematical term he's using, he's just saying that it is simple.
For 2^n to equal 1, the only value n can be is 0. In this case, n is 1-z.
1-z=0. z=1.
What about [tex]z=1 + \frac{2\pi in}{log(2)}[/tex] for any integer n?
No need for that double post :P And we are dealing with the primary branch only, otherwise nothing we talk about here are functions anymore.
I'm sorry you've lost me now. Is it or is it not true that the function 2^(1-z) has poles at [tex]z=1 + \frac{2\pi in}{log(2)}[/tex]?
What do you mean by primary branch?
Oh I see now, the primary branch of the complex log function. I forgot about that.
Still, do we have poles here or not?
Yes! Think about the definition of a simple pole, and what mathwonk said.
1-z=0. z=1.
when it is clearly wrong.
And what's all this talk about it not being a function? I have only ever alluded to 2^n being 1 whose imaginary part, if I am not mistaken, lies between + and - pi.
"For 2^n to equal 1, the only value n can be is 0. In this case, n is 1-z.
1-z=0. z=1. "
I don't understand why that is clearly wrong...
Try [tex]n = \frac{2\pi i}{\log 2} \not = 0[/tex].
Ok fine let me rephrase that then, the only value n can be, in the primary branch on the complex log function which is what we are dealing with me, is zero.
Gib Z said:
Ok fine let me rephrase that then, the only value n can be, IN THE PRIMARY BRANCH OF THE COMPLEX LOG FUNCTION WITH WHICH WE ARE DEALING WITH HERE, is zero.
Erm, o.k, I don't really understand what you are on about. You're talking about the solutions of a complex equation, there's no reason to think we should limit our search to only real numbers.
But furthermore I don't understand why you are talking about the primary branch of the complex log function, it doesn't seem to make sense to the context of the question. I don't think stating it in capitals makes it any more relevant, perhaps you could explain your motive for talking about this better.
Im not limiting the search to real numbers, just the primary branch of the complex log. In this case, the solution happens to be a real number. And We needed to bring the primary branch of the complex log into this because otherwise we would have an infinite number of solutions to choose from to solve 2^(1-z)=1, as the OP noticed.
Ill edit my previous post so its not so capital, that was stupid i realize now.
I think we may have gone off on a bit of a tangent. Thank you for trying to expain Gib Z but I think a few of us do not understand mathwonk's motives for his method and hence don't understand your motives for limiting the number of solutions. Not a clue what's going on there. I myself have only seen two ways of showing that a function has simple poles, namely the limit method that marcusl demonstrated; and finding a Laurent series in order to show that the only nonzero coefficient of a negative power is that corresponding to the power -1. I can't see how mathwonk's method falls into either of these categories.
It would be nice to know though. And I'm still curious as to whether there is a nice way of deducing the exact form of the Laurent series since Zurtex claims that mathematica gives it fairly succinctly.
Just don't know what he's trying to do here.
im using "simply" in the same sense in which he used "simple pole". i.e. a pole is simple, if the reciprocal has a simple zero.
a simple zero at z=a, means a zero of order one.
or it means the taylor series starts with the term c(z-a).
and order of zeroes is a local matter, so it matters not what branch one takes.
so his function has a simple pole if 1 - 2^(1-z) has a simple zero at z=1.
but that occurs iff the derivative of 2^(1-z) is not zero at z=1.
but that derivative is a constant multiple of 2^(1-z) which is never zero.
done.
Thanks for steering this back to the puzzling part!
done.
It seems to me that d/dz of 2^(1-z) cannot establish the order of the singularity. A simple pole must depend on the form of the denominator being, e.g., [1-2^(1-z)]^(-1) as opposed to [1-2^(1-z)]^(-2) or some ill-behaved function of 2^(1-z).
you are not listening. f has a simple pole if 1/f has a simple zero.
and you can of course recognize a simple zero from the derivative.
I am listening but you are not explaining in a way I can understand, and in fact simply keep repeating the same answer. I am apparently not the only one in this thread who has not come across a simple zero before. Perhaps you can explain:
Why does a non-zero derivative define a "simple zero"? Is it because that's the coefficient of the first term in the taylor's series?
