Work,Power and Energy = big headache
  • Thread starter Thread starter biochemnerd
    Energy
The discussion revolves around a physics problem involving a piledriver falling onto a spike, focusing on concepts of work, power, and energy. Participants are tasked with determining the average force exerted on the piledriver by the spike after it falls from a height.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the calculation of forces acting on the piledriver and the spike, questioning the assumptions made about the forces involved. There is a discussion on finding acceleration using kinematics and energy methods, as well as clarifying the distance over which the spike interacts with the piledriver.
The discussion is active with participants providing guidance on how to approach the problem. Some participants have suggested using kinematic equations to find acceleration, while others have clarified the forces that need to be considered. There is an ongoing exploration of the calculations and interpretations of the forces involved.
Participants note confusion regarding the specific forces being calculated and the distances involved in the problem setup. There is an emphasis on understanding the relationship between the piledriver's motion and the forces exerted by the spike.
biochemnerd
1. A 1250 Kg piledriver falls from an initial height of 1.30m above the ground onto a 15kg spike the top of which is initially 0.30m above the ground. The top of the spike finishes at ground level. Determine the average force exerted on the piledriver by the spike.
*Pd=Piledriver
S=Spike
mass of piledriver= 1250kg
h1= 1.3m
h2=0m
g=9.8m/s2
mass of spike=15kg
h1=0.30m
Fnet=F1+F2...
Fnet=Fn(S) + Fg(Pd)
= (15*9.8) + (1250*9.8)
=12397 N
Average= (FnS –FgPd) = FgPd
= FnS /2
= (15*9.8) /2
=73.5 N
Fnet=Fn(S) + Fg(Pd)
=12397 N
therefore, the average force applied on the piledriver by the spike is 73.5N
* i really,reallly, really could use some assistance on this one. its grade 11 physics, so i know it can't be that hard. Any Suggestions?
biochemnerd said:
Fnet=Fn(S) + Fg(Pd)
=12397 N
The force of the spike on the piledriver--which you call Fn(S)--does not equal the weight of the spike. Furthermore, Fn is what you are trying to find, so you just can't assume what it is--you must solve for it.
Do this. Find the acceleration of the piledriver during its interaction with the spike. (Use kinematics.) That will tell you the net force. Then you can solve for the average Fn(S).
how do i find the acceleration if I'm not given the time or v2?
You don't need time--you have the distance. You should know the final speed! :wink: And you can figure out the speed of the piledriver as it hits the spike.
(You can also use energy methods to solve this.)
so... if i use :
Vf(squared)=Vi(squared)+ 2a(d)
9.8(squared)= 0squared +2a (1)
2a=96.04/2
a=48.02 m/s2 ?
*i always forget the value of v2
The distance over which the spike interacts with the piledriver--d--is not 1 m. (1 m is the distance the piledriver falls before hitting the spike.)
thanks. its 0.30m then because that's the point of contact? that would result in the a=160.067 m/s2 ?[did i mention I'm not that good at physics :-) ]
ok, so then i take the acceleration, and do :
Fnet=ma
Fnet = (1250)(160.07)
Fnet= 200083.3 N
so then:
Fave.=(Fg + Fnet) /2
= (12397 +200083.3) /2
=106240.15 N of force
* I'm just getting confused as to what force I'm calculating for: for the piledriver or for the spike?
Fnet=ma
Fnet= 200083.3 N
Good. Note that this is the average net force on the piledriver, since we assumed that the acceleration and thus the force were constant.
Now to find the average force (Fn) exerted by the spike on the piledriver, add up the forces:
Fnet = Fn - mg
and solve for Fn(s). Note that mg is negative, since it acts down; Fnet and Fn both act up, so they are positive. (All forces are already the "average" forces, since we had to pretend they were constant.)
so then:
This is incorrect. (Perhaps you are confusing this with calculating the average speed for uniformly accelerated motion: Vave = (Vi + Vf)/2.)
The only forces we are concerned with are the forces acting on the piledriver: the weight of the piledriver and the normal force exerted by the spike on the piledriver.
has anyone told you that you are really helpful? [its true :) ]
Fnet=Fn-mg
200083.3=Fn-(1250*9.8)
Fn=212333.3 N ?
Looks good. (Round off your answer to a reasonable number of significant figures.)
thanks so,so much !
9K
18K
