How much heat is required to melt a 25 kg block of ice and heat it to 78°C?
  • Thread starter Thread starter linhy
    Heat
To calculate the total heat required to melt a 25 kg block of ice and heat it to 78°C, one must consider the specific heat of ice, the heat of fusion, and the specific heat of water. The specific heat of ice is 2.09 J/g°C, the heat of fusion for ice is 334 J/g, and the specific heat of water is 4.18 J/g°C. The total heat can be calculated using the formula: Q = m * c * ΔT for both the heating of ice to 0°C and the heating of water to 78°C, along with the heat required for melting the ice.
  • Understanding of specific heat capacity
  • Knowledge of heat of fusion
  • Basic algebra for calculations
  • Familiarity with temperature conversion
  • Calculate the heat required to raise the temperature of ice from -10°C to 0°C
  • Determine the heat required to melt the ice at 0°C
  • Calculate the heat required to raise the temperature of water from 0°C to 78°C
  • Combine all calculated heats to find the total heat required
Students studying thermodynamics, physics enthusiasts, and anyone working on heat transfer problems in chemistry or engineering.
linhy
a 25 kg block of ice is heated from -10 celsius to 78 celsius. HOw much heat is required.
You must show us some work before we can help you! Read the PF Homework Help rules.
  • · Replies 17 ·
  • · Replies 26 ·
10K
