Sequences Series geometric series or an arithmetic series?
The discussion revolves around identifying the nature of a specific sequence: 1, 2, 5, 14, 41, 122. Participants explore whether it can be classified as a geometric series or an arithmetic series, and they delve into the derivation of a formula that describes the sequence.
  • Some participants assert that the sequence is neither a geometric series nor an arithmetic series, as it does not exhibit a constant ratio or a constant difference between terms.
  • One participant proposes a difference equation, suggesting that if n>=2, then a_{n}-3a_{n-1}=-1, which could lead to an explicit formula.
  • Another participant notes a pattern in the differences between terms, indicating they are multiples of three, and questions whether this is relevant for deriving a formula.
  • A participant mentions that a finite sequence can be extended in infinitely many ways, implying multiple potential patterns could fit the sequence.
  • One participant provides a closed formula for the sequence: F(N)=\frac{3^N+1}{2}, but expresses uncertainty about how to derive it from the sequence itself.
  • Another participant attempts to relate the sequence to a geometric series through a manipulation of sums, though the clarity of this approach is questioned.
  • There is a discussion about the nature of recurrence relations and the search for the simplest degree relation, with a specific example provided that leads to a characteristic equation.
Participants generally agree that the sequence does not fit neatly into the categories of geometric or arithmetic series. However, there are multiple competing views on how to derive a formula for the sequence, and the discussion remains unresolved regarding the best approach.
Participants express uncertainty about the derivation of the formula and the implications of the patterns observed in the sequence. There are also references to different methods of approaching the problem, indicating a lack of consensus on the most effective technique.
physics246
This is the sequence: 1, 2, 5, 14, 41, 122
1. Is this a geometric series or an arithmetic series?
2. I know the formula is a sub n=[3^(n-1)+1]/2, but how do you get that from a sub n=a sub 1 * r^(n-1), which is the geometric formula for series.
1. Neither.
2. I assume your sequence should be 1,2,5,14,41,122
You don't get it from a geometric series, since it isn't a geometric sequence.
It is neither - geometric series means constant ratio between terms, arithmetic means constant difference.
So how would you get it then, with what formula or method?
Well, if you are clever, you will see that if n>=2, then we have:
[tex]a_{n}-3a_{n-1}=-1[/tex]
Assuming this is the pattern for all the next numbers, you may derive that explicit formula.
So there is no definite way of determining that formula? I see that to get from a term to another you add first 1, then 3, then 9, then 27, then 81 which are multiples of three. Does this have anything to do with determining the formula?
Thanks
A finite sequence can be extended in infinitely many ways, i.e, there exists an infinity of patterns to choose from.
A pattern that fits this is: [tex]F(N)=\frac{3^N+1}{2}, N=0,1,2..[/tex]
I know that that is the pattern, but I was just wondering how to figure that out with a formula or something.
1)neither
2) you can convert it to geometric series >>
t=1+2+5+14+41+122... Tn ------(1)
t= 1+2+5+14+41+122...Tn-Tn-1+Tn ------(2)
now eq 1- 2 and you'll get geometric series .
Can you please explain that more?
Post 5 gives you a difference equation to solve. You also have the solution as a closed formula, to the difference equation, so it is a simple induction argument to verify it.
And yet, in the context of a math education, only one of these is considered to have a "formula". Although we with our modern sensibilities abhor this notion of formula, Euler would concur.
ok
Tn=1+2+5+14+41+122... Tn ------(1)
Tn=0+1+2+5+14+41+122...Tn-1+Tn ------(2)
-------------------------------------------------------------- Eq 1- 2
0 = 1+1+3+3^2+3^3+3^4+... (Tn-Tn-1) - Tn
now transfer that Tn to that side (where zero is) & other side will have (n-1) terms and if you'll not include 1 of (first one) of series then terms will be (n-2) .that fact is that when you get such type of serieses you have to see for diffrences of series .
:devil:
Usualy, assuming that we deal with a homogeneous linear sequence, the recurrence relation which we have to seek is that having the smallest degree, in this case a[k]-4a[k-1]+3a[k-2]=0 which gives immediately the closed form from the OP (k=3,4...).
[The characteristic equation is r^2-4*r+3=0 ---> r1=1; r2=3
Therefore we must seek a solution of the form a[k]=A*(1)^k+B*[(3)^k] (1); A,B = constants
we have a[k=3]=5 and a[k=4]=14 ---> replacing k in (1) with 3 and 4 results a system of equations from which A=1/2 and B=1/6.]
  • · Replies 20 ·
  • · Replies 17 ·
