Calculating Acceleration of a Rocket Launch
  • Thread starter Thread starter leafgirl115
    Physics
The discussion revolves around calculating the average acceleration of a rocket that starts from rest and reaches a velocity of 1500 km/h in 20 seconds. Participants are exploring the conversion of units and the application of the average acceleration formula.
  • Participants discuss the conversion of velocity from km/h to m/s and question the accuracy of the original poster's calculations. There are attempts to clarify the definitions of terms like "delta" and the significance of vector notation in the equations presented.
There is an ongoing exploration of the correct conversion methods and the application of the average acceleration formula. Some participants are providing guidance on unit conversion and the relationship between initial and final velocities, while others express confusion about the calculations and seek clarification.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. There is also a mention of a previous test score, indicating that the original poster is grappling with understanding the material.
leafgirl115
1. What us the Average acceleration of a rocket that starts from a rest, rises vertically and attains a velocity of 1500km/hr [up] in 20 seconds?
v(with arow thing on top)= 1500km/hr[up]= 41.67m/s
(triangle th ing)t=20s
a(with arowo n top)= ?
forula needed: a(arow on top)= v(with arow thing on top)/(triangle)t
a= 41.67m/s / 20s
a= 2.0835 or 2.08m/s^2
[/b
and your question is ?
Have another look at your conversion from km/h to ms-1
The triangle is called "delta", which is defined as "the change in...". The arrow on top signifies that the quantity is a vector; for example, the v with the arrow shows that it is a velocity, which inherently contains the direction (as opposed to speed, which is only a magnitude without a direction).
Now having said all that, your equations look fine. The average acceleration is the change in velocity divided by the change in time, or (delta v)/(delta t). You converted the velocity incorrectly. That is your problem. Might want to check that again.
EDIT: Looks like someone (danago) asked the question first.
I have and I am really confused... the answe should be 75.00 (km/h)/s [up] or 20.83 m/s^2
i just can't get it... I got 8/10 on a little test but i did not get the right answers its so confusing and she did not tell me what i did rong...
Do you know the equation for average acceleration? You are told the intial velocity, the "final" velocity, and the time...if you know how to find the average velocity and understand that, hopefully you can correlate that with finding the average acceleration.
If you are going to express it in km/h/s then it is straightforward division of the two numbers you were given (since v0 is zero). But as the others have said, your conversion of the velocity into m/s is wrong. Remember, there are 1000 meters in 1 kilometer.
should it be 1.500 m/s?
No. If you have 1500 km, how many meters is that?
1500 km/h is the same as 1500000 m/h right? Since there are 1000m in a kilometer. Dividing by 60, you get 25000 m/min, since there are 60 minutes in an hour. Doing the same again (this time, going from minutes->seconds), you get 416.67 m/s. Doing all that is the same as divinding by 3.6, so to convert km/hr to m/s, just divide by 3.6.
opps i whent the oposite way.
I should have 1500000m
ok thanks Dango :D I am geting it now.
can I ask what i did rong in this question?
A dragster slows down from 28m/s[N] in a time of 12s using a parachute and brakes. Calculate the displacement drurring this acceleration(answer should be 245m[n])
delta t=12s
vector vi=25m/s[n]
vector vf=13m/s[n]
delta d=?
delta d=(delta vector v) (delta t)
delta d=(25-13m/s)(12s)
delta d= 144m
Im not quite sure what it is youre asking. It slows from 28m/s^2? Should that be 28m/s? And youre asking how long did the acceleration last, yet the answer is 245 meters?? Shouldnt it be in seconds?
Sory about that i coppied part of the question rong. I fixed it.
A=??
V1=0 A= v2-v1
v2=1500 _________
t1=0 t2-t1
t2=20
A= 1500-0
________ = 1500
20-0 20 A= 75km/hr/s
V= Velocity
A= acceleration
T= Time
  • · Replies 42 ·
