Solve for Wavelength of Commercial FM Radio Station at 90.1 MHz
  • Thread starter Thread starter map7s
The discussion revolves around calculating the wavelength of electromagnetic radiation from a commercial FM radio station broadcasting at a frequency of 90.1 MHz. Participants explore the relationship between frequency and wavelength, particularly in the context of electromagnetic waves.
  • The original poster attempts to use the equation c = wavelength * frequency and expresses confusion about the calculation. Some participants confirm the arithmetic and discuss the implications of different equations related to wave properties.
Participants are actively engaging with the concepts of wavelength and frequency, with some providing clarifications on the differences between the de Broglie relation and the basic wave equation. There is an exploration of how these equations apply to different classes of objects, though no consensus has been reached.
Participants are discussing the properties of electromagnetic radiation and the implications of mass on wave behavior, noting that different assumptions are being made regarding the nature of the waves involved.
map7s
Consider a commercial FM radio station that broadcasts at a frequency of 90.1 MHz. The associated electromagnetic radiation has a wavelength of ? m.
I'm pretty sure that this is a very easy problem, but for some reason, I don'ts really get it.
I was positive that I was supposed to use the equation c=wavelength*f
and I converted the frequency into Hz by multiplying by 1E6
and then I took the value of light (3E8) and divided it by my answer... is there something special about electromagnetic radiation the I failed to factor in?
Nope, assuming you did the arithmetic correctly, your answer should be correct (around 0.3 meters).
thank you so much !
According to de broglie relation lambda=h/mv ...which implies that velocity is inversely proportional to wavelength. But According to the reletion
V=n lambda ... velocity is directly proportional to wavelength... How That diffenence is Causesd ? Am i going wrong Somowhere ?
de broglie implies that velocity is proportional to lambda only for massive particles. Massless particles always travel at c. Where did you get V=n lambda? What is n?
Hey..
n is the frequency of the wave and V=n lambda is the basic Wave equation
Ok, so de broglie says lambda of a massive particle is inversely proportional to the velocity at a fixed mass. V=n*lambda says the the lambda of any wave is directly proportional to velocity at fixed frequency. The two statesments refer to different classes of objects with different properties held fixed. They are two quite different statements.
okay. How it can be different ?de Broglie Equation deals with both particle and wave character ...and V=n*lambda equation deals with wave character.. Then how it can be different ?
The wave character of a massive particle. The formula cited in this problem is for electromagnetic radiation- light.
It's also important that different quantities are being held fixed in the two problems.
11K
35K
