Solving a System of Equations: What Gives?
The discussion revolves around a system of linear equations and the conditions under which it has nontrivial solutions. The original poster is attempting to determine the values of a parameter, c, for which the system has nontrivial solutions, based on the determinant of the coefficient matrix.
  • The original poster calculates the determinant and sets it to zero to find c, but questions arise regarding the nature of solutions obtained. Some participants explore the implications of a zero determinant in relation to trivial and nontrivial solutions.
Participants are actively questioning the assumptions about the relationship between the determinant and the types of solutions. Some guidance is offered regarding the calculation of the determinant and the conditions for nontrivial solutions, though there is no explicit consensus on the correct interpretation.
There is mention of homework constraints and the focus on determinants, which may limit the approaches discussed. The original poster expresses frustration over repeated attempts to solve the problem, indicating a potential misunderstanding of the concepts involved.
discoverer02
This seems like a very simple problem, yet I can't seem to come up with the correct solution.
Determine all the values of c for which the system has nontrivial solutions, and then find all the solutions.
x + 2y + cz = 0
3x - y = 0
-2x + y + z = 0
OK, the system has nontrivial solutions if the determinant = 0.
So I set the determinant = 0 and solve for c.
Using cofactor expansion, I have:
c(3 + 2) + (-1 - 6) ==> c = 7/5.
I plug this into the system and using elementary row operations I still only come up with only the trivial solution x = 0, y = 0,
z = 0. I can't go through the steps here. It would be way too tedious, but I've gone over it several times and come up with the same result. What gives? I was promised that if the det = 0 the system has either 0 solutions or infinitely many solutions. Since x,y,z = 0 is a solution there must be infinitely many solutions.
Where have I gone wrong?
Thanks.
You're doing a good job of ensuring that the system of equations has only trivial solutions by setting the determinant equal to zero (which is why those are all you're getting), but it doesn't help much if you're looking for non-trivial solutions.
cookiemonster
So I need to do the elementary row operations first and reduce to row-echelon form? Once I'm there I set c blah, blah, blah = 0 to eliminate the last equation thereby ensuring infinitely many solutions to the system? This doesn't seem to make use of anything new we learned that the homework problems should refer to. It's a section determinants, but it doesn't seem that determinants are very helpful here.
What're you trying to do in the problem? Are you trying to find non-trivial solutions or trivial ones?
If you're looking for trivial solutions (i.e. x,y,z = 0), then you've done it.
If you're looking for non-trivial solutions, you're not going to set the determinant to 0.
cookiemonster
But doesn't a det = 0 just mean that the system will have either no solutions or infinitely many solutions? And in the case of a homogeneous system, wouldn't it guarantee that you have an infinite number of solutions?
Thanks.
OK, I checked Mathworld/Cramer's Rule and found the following where D is the determinant of a system of equations:
If d = 0 and D = 0, the system has no unique solution.
Wouldn't this mean that if D = 0 and the system of equations is homogeneous then it must have infinitely many solutions?
cookie monster must have had his eyes crossed when looking at this!
discoverer02 is completely correct and cookie monster (much as it hurts me to say it!) is, in this case, completely wrong.
A system of linear equations has a unique solution if and only if the determinant of the coefficient matrix is non-zero. Since a homogenous system of equations always has the trivial solution, the only way there can be non-trivial solutions is if that not a unique solution: in other words, if the determinant is0 just as discoverer02 said.
The only thing wrong with discoverer02's solution is that he calculated the determinant incorrectly!
The determiant is |1 2 c|
|3 -1 0|
|-2 1 1|
Expanding on the third column, that is
|3 -1| |1 2|
c|-2 1|+ 1|3 -1|= c((3)(1)-(-1)(-2))+ (1(-1)-3(2))
= c(3-2)+ (-1-6)
(not "c(3+2)"!)
= c- 7= 0 so c= 7, not 7/5.
In particular, if c= 7, then x= 1, y= 3, z= -1 satisfies
x+ 2y+ 7z= 1+ 2(3)+ 7(-1)= 7- 7= 0
3x- y = 3- 3 = 0
-2x+ y+ z= -2+ 3 - 1 = 1- 1= 0.
Thanks very much for the help.
I looked at this at least a dozen times and didn't catch that.
Argh!
Maybe I should stop sticking my nose in where it has no business...
retardeduneducatedmonster
Actually cookiemonster, our brief dialogue really got me thinking about this problem and these types of problems, so whether you think so or not, you were a great help.
discoverer02
  • · Replies 25 ·
  • · Replies 40 ·
  • · Replies 29 ·
