| Thread Closed |
Parallel RLC circuit: find resonant frequency and Input at that frequency |
Share Thread | Thread Tools |
| Apr11-07, 05:38 AM | #1 |
In the circuit below, find the resonant frequency ([itex]\omega_0[/itex]) and [itex]Z_{IN}\left(\omega_0\right)[/itex]. ![]() 2. Relevant equations [tex]\omega_0\,=\,\frac{1}{\sqrt{LC}}[/tex] 3. The attempt at a solution The resonant frequency is easy to find: [tex]\omega_0\,=\,\frac{1}{\sqrt{20mH\,9\mu F}}\,=\,2357\,\frac{rad}{s}[/tex] Now I reconfigure the circuit a little to combine the resistor and capacitor into the element [itex]Z_1[/itex]: ![]() Does that seem right? Now I get this: [tex]Z_{IN}\,=\,\frac{1}{1\Omega}\,+\,\frac{1}{j\omega\,0.02}\,+\,9X10^{-6}j\omega\,+\,10[/tex] [tex]Z_{IN}\,=\,\frac{1}{j\omega\,0.02}\,+\,9X10^{-6}j\omega\,+11[/tex] Now what do I do? |
| Apr11-07, 06:01 AM | #2 |
Recognitions:
| Apr11-07, 06:07 AM | #3 |
Yep, I could just substitute the [itex]\omega_0[/itex] value into the last equation. Would that then be the final answer for [itex]Z_{IN}(\omega_0)[/itex]? Is there any simplification I can do for the j's?
[tex]Z_{IN}\left(\omega_0\right)\,=\,\frac{1}{j(2357)\,0.02}\,+\,9X10^{-6}j(2357)\,+11[/tex] [tex]Z_{IN}\left(\omega_0\right)\,=\,11\,+\,\frac{1}{47.14\,j}\,+\,0.0212\,j[/tex] |
| Apr11-07, 08:13 AM | #4 |
[tex]Z_{IN}\left(\omega_0\right)\,=\,518.5j\,+\,0.0006[/tex]
Can someone double-check that the above is correct? |
| Apr11-07, 11:58 AM | #5 |
Your mistake is in using [tex]\omega_0\,=\,\frac{1}{\sqrt{LC}}[/tex] to calculate the resonant frequency. This is valid only for series or parallel RLC circuits. For different connections you must calculate the complex impedance [tex]Z_{IN}[/tex] and make the imaginary part zero. |
| Nov18-07, 05:08 AM | #6 |
| Sep24-08, 01:41 PM | #7 |
To actually figure out the resonant impedance you use w0 for XL and XC or ZL and ZC depending on nomenclature u maybe using it’s the same thing. Any way when the circuit is at resonance it is to be completely resistive like previously stated. But what that means is XL – XC = 0. To find XL the equation is (w0*L) and the equation for XC is (1/(w0*C)). Now once you find XL and XC you put those in their respective places in the circuit as though they were resistors. Now you can solve for the resonant impedance of the circuit like any parallel or series circuit.
| Sep24-08, 10:36 PM | #8 |
Recognitions:
Did you really have to resurrect a 10-month old homework thread just to answer it? The OP has probably long lost interest in the thread.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Parallel RLC circuit: find resonant frequency and Input at that frequency
| find the frequency in an LRC circuit | Introductory Physics Homework | 1 | ||
| How do we find the frequency response for a circuit | Engineering, Comp Sci, & Technology Homework | 2 | ||
| Frequency response: Find H(s) for a circuit w/ 2 res. - 2 Inductors and an I - source | Introductory Physics Homework | 5 | ||
| Resonant Frequency | General Physics | 4 | ||
| what is the resonance frequency expression for a parallel RLC circuit? | General Physics | 6 | ||
